Hi, just checking in to see if there are any other updates. I’m also attaching a simpler version of the program that illustrates the bug. It still seems to be present in nvfortran 24.11
program aocc_run_test
implicit none
real :: arr_in1(0:10, 2:5), arr1(0:10,2:5)
integer i, j
do i=0,10
do j=2,5
arr_in1(i,j) = 1000*i+j
end do
end do
call evaluate(arr_in1,arr1)
contains
function justcopy(arr_in)
implicit none
real, intent(in) :: arr_in(0:,:)
real :: justcopy(0:ubound(arr_in,dim=1), 2:5) !This works for "A" GNU,Intel/InteLLVM,lfortran,NAG,IBM. Does not work for "B" AOCC, NVidia, ARM.
!real :: justcopy(0:size(arr_in,dim=1)-1, 2:5) !This works for all compilers
write(*,*) "arr_in, dim 1 (lb,ub,sz):", lbound(arr_in,dim=1),ubound(arr_in,dim=1),size(arr_in,1)
write(*,*) "arr_in, dim 2 (lb,ub,sz):", lbound(arr_in,dim=2),ubound(arr_in,dim=2),size(arr_in,2)
write(*,*) "justcp, dim 1 (lb,ub,sz):", lbound(justcopy,dim=1),ubound(justcopy,dim=1),size(justcopy,1)
write(*,*) "justcp, dim 2 (lb,ub,sz):", lbound(justcopy,dim=2),ubound(justcopy,dim=2),size(justcopy,2)
justcopy=arr_in
end function justcopy
subroutine evaluate(arr_in1,arr_out1)
implicit none
real, intent(in) :: arr_in1(:,:)
real, intent(out) :: arr_out1(:,:)
real, allocatable :: X(:,:)
!arr_out1 = justcopy(arr_in1)
X = justcopy(arr_in1)
write(*,*) "X , dim 1 (lb,ub,sz):", lbound(X,dim=1),ubound(X,dim=1),size(X,1)
write(*,*) "X , dim 2 (lb,ub,sz):", lbound(X,dim=2),ubound(X,dim=2),size(X,2)
if (size(X,1) /= size(arr_in1,1)) then
print "(A,I2,A,I2)","Error: size of X(dim1)=",size(X,1),&
" was not equal to size of arr_in1(dim1)=",size(arr_in1,1)
error stop 1
end if
arr_out1 = X
end subroutine evaluate
end program aocc_run_test
