Hi all,
Here is my platform: WINDOWS XP 32-bit (SP3)/CUDA 2.0/VS 8.0 sp1/8600m GS.
And here is my NVCC -cuda cmd format:
D:\CUDA\bin\nvcc.exe D:/Jesper/Med/workspace/Slicer3/Modules/VolumeRenderingCuda/CUDA_renderAlgo.cu -DNVCC --keep -cuda -o D:/Jesper/Med/workspace/Slicer3-build/src/cuda/CUDA_renderAlgo.cu_generated.c -I D:/CUDA/include...
After the above cmd finished successfully and c file generated, I got the following error when trying to build it into DLL by TP:
2>Compiling…
2>cl: Command line warning D9025 : overriding ‘/TP’ with ‘/TC’
2>CUDA_renderSingleSlice.cu_generated.c
2>d:\cuda\include\host_config.h(89) : error C2061: syntax error : identifier ‘type_info’
2>d:\cuda\include\host_config.h(89) : error C2059: syntax error : ‘;’
2>D:\Program Files (x86)\Microsoft Visual Studio 8\VC\bin/…\INCLUDE\vadefs.h(50) : error C2059: syntax error : ‘string’
…(more than 100 here)
It seems to be something related to configuration. Here is the first several lines in the c file which may cause the error:
#line 1 "CUDA_renderAlgo.cudafe1.cpp"
#line 1 "D:/Jesper/Med/workspace/Slicer3/Modules/VolumeRenderingCuda/CUDA_renderAlgo.cu"
#line 89 "d:\cuda\include\host_config.h"
class type_info;
Could anyone help on this? Thanks in advance.
