I am trying to install the nvidia drivers on an old PC (2013 vintage) that does not have secure boot. It fails due to module signing. From the logs I get this. Searched but didn’t see any answers. Suggestions?
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 340.108 -k 5.19.16-602.inttf.fc37.x86_64
: This system doesn’t support Secure Boot
Sign command: /lib/modules/5.19.16-602.inttf.fc37.x86_64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module:
Cleaning build area...
make -j8 KERNELRELEASE=5.19.16-602.inttf.fc37.x86_64 module KERNEL_UNAME=5.19.16-602.inttf.fc37.x86_64; make -C uvm module KERNEL_UNAME=5.19.16-602.inttf.fc37.x86_64 KBUILD_EXTMOD=/var/lib/dkms/nvidia/340.108/build/uvm..............(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.19.16-602.inttf.fc37.x86_64 (x86_64)
Consult /var/lib/dkms/nvidia/340.108/build/make.log for more information.
From /var/lib/dkms/nvidia/340.108/build/make.log
/var/lib/dkms/nvidia/340.108/build/os-interface.h:27:10: fatal error: stdarg.h: No such file or directory
27 | #include <stdarg.h>
In file included from /var/lib/dkms/nvidia/340.108/build/nv-gvi.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-i2c.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-cray.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-chrdev.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-drm.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-acpi.c:14:
In file included from /var/lib/dkms/nvidia/340.108/build/nv-mempool.c:14:
compilation terminated.
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-acpi.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-chrdev.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-cray.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-dma.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-drm.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-gvi.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-i2c.o] Error 1
make[2]: *** [scripts/Makefile.build:249: /var/lib/dkms/nvidia/340.108/build/nv-mempool.o] Error 1
make[1]: *** [Makefile:1850: /var/lib/dkms/nvidia/340.108/build] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.19.16-602.inttf.fc37.x86_64'
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make: *** [Makefile:197: nvidia.ko] Error 1
make: Entering directory '/var/lib/dkms/nvidia/340.108/build/uvm'
cd ./..; make module SYSSRC=/lib/modules/5.19.16-602.inttf.fc37.x86_64/source SYSOUT=/lib/modules/5.19.16-602.inttf.fc37.x86_64/build KBUILD_EXTMOD=./..
make[1]: Entering directory '/var/lib/dkms/nvidia/340.108/build'
NVIDIA: calling KBUILD...
make[2]: Entering directory '/usr/src/kernels/5.19.16-602.inttf.fc37.x86_64'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (GCC) 12.2.1 20220819 (Red Hat 12.2.1-2)
You are using: cc (GCC) 12.2.1 20220819 (Red Hat 12.2.1-2)
make -f ./scripts/Makefile.build obj=.. \
single-build= \
need-builtin=1 need-modorder=1
scripts/Makefile.build:43: ../Makefile: No such file or directory
make[3]: *** No rule to make target '../Makefile'. Stop.
make[2]: *** [Makefile:1850: ..] Error 2
make[2]: Leaving directory '/usr/src/kernels/5.19.16-602.inttf.fc37.x86_64'
make[1]: *** [Makefile:197: nvidia.ko] Error 1
make[1]: Leaving directory '/var/lib/dkms/nvidia/340.108/build'
make: *** [Makefile:221: ../Module.symvers] Error 2
make: Leaving directory '/var/lib/dkms/nvidia/340.108/build/uvm'
nvidia-bug-report.log.gz (52.1 KB)
