I recently began dabbling with Docker containers. I am trying to build the jetson inference files in docker container. I’m using l4t-base: r32:3:1 as the base image and I’m following the build instructions from the jetson-inference github page: build instructions. I successfully built this on the host OS before, but not successful in the container.
When building with cmake, I get the following errors after installing models and pytorch:
CMake Error:
> The following variables are used in this project, but they are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the CMake files:
> CUDA_nppicc_LIBRARY (ADVANCED)
> linked by target “jetson-utils” in directory /home/jetson-inference/utils
> – Configuring incomplete, errors occurred!
> See also “/home/jetson-inference/build/CMakeFiles/CMakeOutput.log”.
> See also “/home/jetson-inference/build/CMakeFiles/CMakeError.log”
Diving further into the error logs, it looks like the “pthread_create” function doesn’t exist
Please advise if I’m performing steps correctly or if I should be following a different procedure.
Much thanks!!
Anthony
