Docker container release ETA for L4T R36.4.0
New user of Jetson. Out of box my 64G Dev kit, while running from shared memory, the inference container ran. I didn’t note the L4T version then. I then flashed to run from a NVMe drive.
Now, docker: Error response from daemon: manifest for dustynv/jetson-inference:r36.4.0 not found: manifest unknown: manifest unknown.
If there is a long lead time, how can I work around this? Can I use a historical version of L4T?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
We have docker of Jetpack 6.1(r36.4). Please check the webpage:
NVIDIA L4T JetPack | NVIDIA NGC
my issue is with dustynv/jetson-inference. Are there other steps after the JetPack install?
r36.4 is not supported yet.
Please try to build the container directly with the Dockerfile.
