rgohain
December 21, 2022, 3:08pm
1
I am trying to build the codein Jetson Nano B01 from the below link:
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="aux-docker.md">Back</a> | <a href="imagenet-console-2.md">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>System Setup</sup></p>
# Building the Project from Source
Provided with the repo is a library of TensorRT-accelerated deep learning networks for image recognition, object detection with localization (i.e. bounding boxes), and semantic segmentation. This inferencing library (`libjetson-inference`) is intended to be run on the Jetson, and includes support for both C++ and Python. Various pre-trained DNN models are automatically downloaded to get you up and running quickly.
The latest source code or [Docker container](aux-docker.md) can be used onboard your Jetson once your device has been [flashed with JetPack](jetpack-setup-2.md) or setup with the pre-populated [SD card image](https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#write). You can run the pre-built [Docker container](aux-docker.md) without needing to compile the project or install PyTorch yourself.
### Quick Reference
If you aren't using the [Docker container](aux-docker.md), here's a condensed form of the commands to build/install the project directly on your Jetson:
``` bash
$ sudo apt-get update
$ sudo apt-get install git cmake libpython3-dev python3-numpy
$ git clone --recursive https://github.com/dusty-nv/jetson-inference
$ cd jetson-inference
This file has been truncated. show original
while executing the instruction of “cmake …/ ” I am getting configuration incomplete error. I am sharing the CMakeOutput.log file, but unable to figure out where the issue is. Can anyone help me to fix this issue?
CMakeOutput.log (43.5 KB)
Hi @rgohain , can you share the terminal log of when you run cmake ../ as opposed to the CMakeOutput.log? I can’t seem to find any errors in that.
