Hi there
I am following the NVIDIA tutorial: https://developer.nvidia.com/embedded/twodaystoademo
Unfortunately I always got the same erroe while trying “Building the Project from Source”
The following work:
$ sudo apt-get update
$ sudo apt-get install git cmake libpython3-dev python3-numpy
$ git clone --recursive GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson.
$ cd jetson-inference
$ mkdir build
$ cd build
BUT as soon as I try the next command (cmake …/) I got errors…
$ cmake …/
$ make
$ sudo make install
$ sudo ldconfig
flu@flubuntu:~/jetson-inference/build$ cmake …/
Note: this project uses git submodules in the source tree.
if you haven’t already, run the following command from
the project’s root directory:
git submodule update --init
– using patched FindCUDA.cmake
CUDA_TOOLKIT_ROOT_DIR not found or specified
– Could NOT find CUDA (missing: CUDA_TOOLKIT_ROOT_DIR CUDA_NVCC_EXECUTABLE CUDA_INCLUDE_DIRS CUDA_CUDART_LIBRARY)
– CUDA version:
– system arch: x86_64
– output path: /home/flu/jetson-inference/build/x86_64
– Copying /home/flu/jetson-inference/c/detectNet.h
– Copying /home/flu/jetson-inference/c/homographyNet.h
– Copying /home/flu/jetson-inference/c/imageNet.h
– Copying /home/flu/jetson-inference/c/segNet.h
– Copying /home/flu/jetson-inference/c/superResNet.h
– Copying /home/flu/jetson-inference/c/tensorNet.h
– Copying /home/flu/jetson-inference/c/imageNet.cuh
– Copying /home/flu/jetson-inference/calibration/randInt8Calibrator.h
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
CMake Warning at tools/camera-capture/CMakeLists.txt:8 (find_package):
By not providing “FindQt5.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “Qt5”, but
CMake did not find one.
Could not find a package configuration file provided by “Qt5” with any of
the following names:
Qt5Config.cmake
qt5-config.cmake
Add the installation prefix of “Qt5” to CMAKE_PREFIX_PATH or set “Qt5_DIR”
to a directory containing one of the above files. If “Qt5” provides a
separate development package or SDK, be sure it has been installed.
– camera-capture: Qt5Widgets package not found, skipping…
– camera-capture: run ‘sudo apt-get install qtbase5-dev’
– jetson-utils: building as submodule, /home/flu/jetson-inference
– Copying /home/flu/jetson-inference/utils/XML.h
– Copying /home/flu/jetson-inference/utils/commandLine.h
– Copying /home/flu/jetson-inference/utils/filesystem.h
– Copying /home/flu/jetson-inference/utils/mat33.h
– Copying /home/flu/jetson-inference/utils/pi.h
– Copying /home/flu/jetson-inference/utils/rand.h
– Copying /home/flu/jetson-inference/utils/timespec.h
– Copying /home/flu/jetson-inference/utils/camera/gstCamera.h
– Copying /home/flu/jetson-inference/utils/camera/v4l2Camera.h
– Copying /home/flu/jetson-inference/utils/codec/gstDecoder.h
– Copying /home/flu/jetson-inference/utils/codec/gstEncoder.h
– Copying /home/flu/jetson-inference/utils/codec/gstUtility.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaFont.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaMappedMemory.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaNormalize.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaOverlay.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaRGB.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaResize.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaUtility.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaWarp.h
– Copying /home/flu/jetson-inference/utils/cuda/cudaYUV.h
– Copying /home/flu/jetson-inference/utils/display/glDisplay.h
– Copying /home/flu/jetson-inference/utils/display/glTexture.h
– Copying /home/flu/jetson-inference/utils/display/glUtility.h
– Copying /home/flu/jetson-inference/utils/image/imageIO.h
– Copying /home/flu/jetson-inference/utils/image/loadImage.h
– Copying /home/flu/jetson-inference/utils/input/devInput.h
– Copying /home/flu/jetson-inference/utils/input/devJoystick.h
– Copying /home/flu/jetson-inference/utils/input/devKeyboard.h
– Copying /home/flu/jetson-inference/utils/network/Endian.h
– Copying /home/flu/jetson-inference/utils/network/IPv4.h
– Copying /home/flu/jetson-inference/utils/network/NetworkAdapter.h
– Copying /home/flu/jetson-inference/utils/network/Socket.h
– Copying /home/flu/jetson-inference/utils/threads/Event.h
– Copying /home/flu/jetson-inference/utils/threads/Mutex.h
– Copying /home/flu/jetson-inference/utils/threads/Process.h
– Copying /home/flu/jetson-inference/utils/threads/Thread.h
– trying to build Python bindings for Python versions: 2.7;3.6;3.7
– detecting Python 2.7…
– Python 2.7 wasn’t found
– detecting Python 3.6…
– found Python version: 3.6 (3.6.8)
– found Python include: /usr/include/python3.6m
– found Python library: /usr/lib/x86_64-linux-gnu/libpython3.6m.so
– CMake module path: /home/flu/jetson-inference/utils/cuda;/home/flu/jetson-inference/utils/python/bindings
– NumPy ver. 1.13.3 found (include: /usr/lib/python3/dist-packages/numpy/core/include)
– found NumPy version: 1.13.3
– found NumPy include: /usr/lib/python3/dist-packages/numpy/core/include
– detecting Python 3.7…
– Python 3.7 wasn’t found
– Copying /home/flu/jetson-inference/utils/python/examples/camera-viewer.py
– Copying /home/flu/jetson-inference/utils/python/examples/cuda-from-numpy.py
– Copying /home/flu/jetson-inference/utils/python/examples/cuda-to-numpy.py
– Copying /home/flu/jetson-inference/utils/python/examples/gl-display-test.py
– Copying /home/flu/jetson-inference/python/examples/detectnet-camera.py
– Copying /home/flu/jetson-inference/python/examples/detectnet-console.py
– Copying /home/flu/jetson-inference/python/examples/imagenet-camera.py
– Copying /home/flu/jetson-inference/python/examples/imagenet-console.py
– Copying /home/flu/jetson-inference/python/examples/my-detection.py
– Copying /home/flu/jetson-inference/python/examples/my-recognition.py
– Copying /home/flu/jetson-inference/python/examples/segnet-batch.py
– Copying /home/flu/jetson-inference/python/examples/segnet-camera.py
– Copying /home/flu/jetson-inference/python/examples/segnet-console.py
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_CUDART_LIBRARY (ADVANCED)
linked by target “jetson-inference” in directory /home/flu/jetson-inference
linked by target “imagenet-console” in directory /home/flu/jetson-inference/examples/imagenet-console
linked by target “imagenet-camera” in directory /home/flu/jetson-inference/examples/imagenet-camera
linked by target “detectnet-console” in directory /home/flu/jetson-inference/examples/detectnet-console
linked by target “detectnet-camera” in directory /home/flu/jetson-inference/examples/detectnet-camera
linked by target “segnet-console” in directory /home/flu/jetson-inference/examples/segnet-console
linked by target “segnet-camera” in directory /home/flu/jetson-inference/examples/segnet-camera
linked by target “trt-bench” in directory /home/flu/jetson-inference/tools/trt-bench
linked by target “trt-console” in directory /home/flu/jetson-inference/tools/trt-console
linked by target “jetson-utils” in directory /home/flu/jetson-inference/utils
linked by target “jetson-utils-python-36” in directory /home/flu/jetson-inference/utils/python/bindings
linked by target “jetson-inference-python-36” in directory /home/flu/jetson-inference/python/bindings
CUDA_TOOLKIT_INCLUDE (ADVANCED)
used as include directory in directory /home/flu/jetson-inference
used as include directory in directory /home/flu/jetson-inference/docs
used as include directory in directory /home/flu/jetson-inference/examples
used as include directory in directory /home/flu/jetson-inference/examples/imagenet-console
used as include directory in directory /home/flu/jetson-inference/examples/imagenet-camera
used as include directory in directory /home/flu/jetson-inference/examples/detectnet-console
used as include directory in directory /home/flu/jetson-inference/examples/detectnet-camera
used as include directory in directory /home/flu/jetson-inference/examples/segnet-console
used as include directory in directory /home/flu/jetson-inference/examples/segnet-camera
used as include directory in directory /home/flu/jetson-inference/tools
used as include directory in directory /home/flu/jetson-inference/tools/camera-capture
used as include directory in directory /home/flu/jetson-inference/tools/trt-bench
used as include directory in directory /home/flu/jetson-inference/tools/trt-console
used as include directory in directory /home/flu/jetson-inference/utils
used as include directory in directory /home/flu/jetson-inference/utils/camera/camera-viewer
used as include directory in directory /home/flu/jetson-inference/utils/camera/v4l2-console
used as include directory in directory /home/flu/jetson-inference/utils/camera/v4l2-display
used as include directory in directory /home/flu/jetson-inference/utils/display/gl-display-test
used as include directory in directory /home/flu/jetson-inference/utils/python
used as include directory in directory /home/flu/jetson-inference/utils/python/bindings
used as include directory in directory /home/flu/jetson-inference/python
used as include directory in directory /home/flu/jetson-inference/python/bindings
– Configuring incomplete, errors occurred!
See also “/home/flu/jetson-inference/build/CMakeFiles/CMakeOutput.log”.
Please find attached the CmakeOutput.log
Can someone help me?
Thank you so much in advance.
CMakeOutput.log (43.9 KB)
