About installation of libraries on jetson nano
I’m setting up an object detection project on my Jetson Nano. The repository was cloned successfully from GitHub, and I installed PyTorch as per the instructions in the repo. However, when I attempt to build the project using CMake, I encounter the following error:
1.System Configuration:
Jetson Device: Jetson Nano
OS: Ubuntu 20.04 (JetPack 5.x)
Python Version: Python 3.8
CUDA Version: 11.4
CMake Version: (Specify your version, e.g., 3.21)
2.Command Executed:
cmake …
3.Error Output:
CMake Error:
Some of the libraries being used in the project are not set to be found:
Could not find package ‘example_library’.
Missing file ‘/path/to/some_required_dependency’.
Steps Taken:
  1. Cloned the GitHub repository:
git clone <repository_link>
cd <repository_name>
Installed dependencies and PyTorch as per the GitHub instructions.
Ran the CMake build:
mkdir build
cd build
cmake …
Additional Info:
  • I checked for the missing libraries and confirmed that some were installed using apt-get install, but the error persists.
  • Updated the environment variables for PATH and LD_LIBRARY_PATH.
Questions:
  1. Is there a common reason why libraries are not found in CMake on Jetson Nano?
  2. Do I need to install specific JetPack or CMake dependencies to resolve this issue?
  3. Should I modify the CMakeLists.txt file to point to library paths?
The error is not related to the device but to the source code you are using.
Have you tried to compile the library on other environments?
