Hello, I tried using the command “./nvbuild. sh - o $PWD/kernel_out” to build the kernel. After the first compilation, I modified the imx219. c program and re executed the command “./nvbuild. sh - o $PWD/kernel_out”, but the generated nv_imx219. ko did not change. What is the problem?
hello wangjing1,
may I double confirm the L4T version you’re now using?
please see-also Preparing to Build External Kernel Modules.
