Description
Hi, I am trying to build a U-Net like the one here (GitHub - milesial/Pytorch-UNet: PyTorch implementation of the U-Net for image semantic segmentation with high quality images) by compiling it and saving the serialzed trt engine. However, the process is too slow. Takes 45min for 2048*2048 resolution. Is there anyway to speed up the network serialization?
Environment
TensorRT Version: TensorRT-7.2.3.4
GPU Type: NVIDIA GeForce GTX 1660 Ti with Max-Q Design
Nvidia Driver Version: 27.21.14.6079
CUDA Version: 11
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
Hi @oelgendy1,
We request you to provide more details. Could you please let us know how are you building tensorrt engine.
Thank you.
Thanks @spolisetty for your reply. I am using the same method in sampleOnnxMNIST.cpp
https://github.com/NVIDIA/TensorRT/blob/master/samples/opensource/sampleOnnxMNIST/sampleOnnxMNIST.cpp
I am using same build parameters as in the sample code. Then, I save the serialized engine using
nvinfer1::IHostMemory* serializedModel = mEngine->serialize();
std::ofstream ofs(engineName, std::ios::out | std::ios::binary);
ofs.write((char*)(serializedModel->data()), serializedModel->size());
ofs.close();
I also tried to use tensorrt.exe and it is very slow as well. It takes 45 min on my machine to build a U-Net engine for 2048x2048 image!
Does the workspace size relate to the network build time? And if I reduced it, will it get a sub-optimal serialized network?
Hi @oelgendy1,
Could you please share the ONNX model with us to try from our end. Meanwhile we request you to check the GPU utilization during serialization. Also please refer (Section - How do I choose the optimal workspace size),
Thank you.
Thanks @spolisetty for your reply. I tried other GPU and the network build is faster (10min) It highly depends on the GPU
