Hi!
I am trying to build the kit-extensions-template-cpp repo on Ubuntu 22.04 with the --no-docker flag on the build.sh script.
When invoking build.sh without parameters, building works fine, as long as Docker is installed.
But once I try to use the --no-docker flag (after a clean), I get linker errors.
/usr/bin/ld: ../../../_build/intermediate/linux-x86_64/omni.example.cpp.ui_widget.python/x86_64/debug/BindCppWidget.o: in function `void omni::ui::StyleContainer::_initializeBlock<omni::ui::StyleColorProperty, char const*>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, omni::ui::StyleColorProperty, char const*)':
/home/jacobs/kit-extension-template-cpp/_compiler/gmake2/omni.example.cpp.ui_widget.python/../../../_build/linux-x86_64/debug/kit/dev/include/omni/ui/StyleContainer.h:319: undefined reference to `omni::ui::StyleContainer::_parseScopeString(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, omni::ui::StyleContainer::State&)'
/usr/bin/ld: /home/jacobs/kit-extension-template-cpp/_compiler/gmake2/omni.example.cpp.ui_widget.python/../../../_build/linux-x86_64/debug/kit/dev/include/omni/ui/StyleContainer.h:327: undefined reference to `omni::ui::StyleContainer::_createStyleStateGroup(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:107: ../../../_build/linux-x86_64/debug/exts/omni.example.cpp.ui_widget/omni/example/cpp/ui_widget/_example_cpp_widget.cpython-37m-x86_64-linux-gnu.so] Error 1
make: *** [Makefile:140: omni.example.cpp.ui_widget.python] Error 2
make: *** Waiting for unfinished jobs....
ExampleUsdExtension.cpp
g++ -MMD -MP -DDEBUG -DOMNI_COMPILE_AS_MODULE -DNOMINMAX -DNDEBUG -I../../../include -I../../../_build/target-deps -I../../../_build/target-deps/carb_sdk_plugins/include -I../../../_build/linux-x86_64/debug/kit/dev/include -I../../../source/extensions/omni.example.cpp.usd/include -I../../../source/extensions/omni.example.cpp.usd/plugins/omni.example.cpp.usd -I../../../_build/target-deps/nv_usd/release/include -I../../../_build/target-deps/python/include/python3.7m -m64 -Werror -Wundef -O0 -fPIC -g -std=c++17 -Wall -fvisibility=hidden -D_FILE_OFFSET_BITS=64 -D_GLIBCXX_USE_CXX11_ABI=0 -Wno-deprecated-declarations -Wno-deprecated -Wno-unused-variable -pthread -lstdc++fs -Wno-undef -o "../../../_build/intermediate/linux-x86_64/omni.example.cpp.usd.plugin/x86_64/debug/ExampleUsdExtension.o" -MF "../../../_build/intermediate/linux-x86_64/omni.example.cpp.usd.plugin/x86_64/debug/ExampleUsdExtension.d" -c "../../../source/extensions/omni.example.cpp.usd/plugins/omni.example.cpp.usd/ExampleUsdExtension.cpp"
Linking omni.example.cpp.usd.plugin
g++ -o "../../../_build/linux-x86_64/debug/exts/omni.example.cpp.usd/bin/libomni.example.cpp.usd.plugin.so" ../../../_build/intermediate/linux-x86_64/omni.example.cpp.usd.plugin/x86_64/debug/ExampleUsdExtension.o -L../../../_build/target-deps/carb_sdk_plugins/_build/linux-x86_64/debug -L../../../_build/linux-x86_64/debug/kit/plugins -L../../../_build/target-deps/nv_usd/release/lib -L/usr/lib64 -m64 -shared -Wl,-soname=libomni.example.cpp.usd.plugin.so -Wl,-rpath,'$ORIGIN' -Wl,--export-dynamic -Wl,--disable-new-dtags -Wl,-rpath,../../../_build/target-deps/nv_usd/release/lib:../../../_build/target-deps/python/lib: -larch -lgf -lsdf -ltf -lusd -lusdGeom -lusdUtils
[2023-01-18 14:47:11,176][ERROR][omni.repo.man.utils] error running: ['make', '--directory=/home/jacobs/kit-extension-template-cpp/_compiler/gmake2', '--stop', 'config=debug_x86_64', '-j24', '--output-sync', 'verbose=1'], code: 2, message: ""
BUILD FAILED for debug
[2023-01-18 14:47:11,176][ERROR][omni.repo.man.entry] Tool exited with return code: 2, raising exception.
[2023-01-18 14:47:11,176][ERROR][omni.repo.man.entry] Exception encountered while running repo_build via ['tools/repoman/repoman.py', 'build', '--no-docker']:
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_man/omni/repo/man/entry.py", line 350, in run_tool
options.func(options)
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_man/omni/repo/man/entry.py", line 201, in <lambda>
func=lambda args, func=func, config=merged_tool_config: func(args, config),
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_build/omni/repo/build/main.py", line 967, in run_repo_tool
run_build(options, repo_folders, None, config)
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_build/omni/repo/build/main.py", line 795, in run_build
build_target=options.target,
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_build/omni/repo/build/main.py", line 540, in build
'error_context': settings.build_error_context,
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_man/omni/repo/man/nvteamcity.py", line 145, in wrapper
result = func(*args, **kwargs)
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_build/omni/repo/build/build.py", line 397, in build_with_make
teamcity_block_name=f"Build {make_platform_target} {config.capitalize()}"
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_man/omni/repo/man/nvteamcity.py", line 190, in wrapper
File "/home/jacobs/kit-extension-template-cpp/_repo/deps/repo_build/omni/repo/build/build.py", line 191, in do_build
sys.exit(returncode)
SystemExit: 2
Do I need special dependencies when building without docker?
Background is that I want to run the build script from an Azure pipeline, and this apparently poses some problems because of the usage of docker in the build process.
I would be interested to know if someone managed to build the repo (on Linux) without docker, and with what setup this is possible.
Any pointers on how the build the repo in an Azure pipeline would be welcome, too. The build fails in the pipeline with ubuntu-latest as base vmImage in the same way as on my local machine. To be honest I am not really familiar with Azure pipelines and their agents, though.
Thanks a lot!
Cheers,
Arne
