Building nvinferserver from source generates different lib than shipped lib
When I use prebuilt nvinferserver lib (libnvds_infer_server.so) provided with deepstream 6.2, everything works well with my setup where I use extraInputProcess feature. However, when I compile the lib myself using provided Makefile it doesn’t work. Sometimes pipeline crashes without an error when initializing the model or throws CUDA Errors. However, It works when built with optimization level 0 (O0).
I am wondering if you have provided the wrong source files in the docker image or cuda compilation has a driver or other dependencies.
It is just completely random.
Error 1:
Cuda failure: status=2
ERROR: Error: Could not allocate surface buffer
ERROR: Failed to add surface buffer into pool
ERROR: Failed to creat nvbufsurface
ERROR: cudaMalloc failed, cuda err_no:2, err_str:cudaErrorMemoryAllocation
ERROR: create cuda tensor buf failed, dt:kFp32, dims:3x700x500, name:
ERROR: Failed to create cuda tensor buffers
Error 2:
ERROR: create cuda tensor buf failed, dt:kFp32, dims:4, name:BBOX
ERROR: create tensor: BBOX failed for map pool: extra_input_gpu_tensors
ERROR: create extra_input_gpu_tensors pool failed.
0:00:07.361871048 2144239 0x3e79ad0 ERROR nvinferserver gstnvinferserver.cpp:407:gst_nvinfer_server_logger:<secondary_inference_inference> nvinferserver[UID 10]: Error in loadExtraProcessor() <infer_cuda_context.cpp:194> [UID = 10]: extra processor allocating inputs failed., nvinfer error:NVDSINFER_RESOURCE_ERROR
0:00:07.361901753 2144239 0x3e79ad0 ERROR nvinferserver gstnvinferserver.cpp:407:gst_nvinfer_server_logger:<secondary_inference_inference> nvinferserver[UID 10]: Error in fixateInferenceInfo() <infer_cuda_context.cpp:173> [UID = 10]: Load extra processing functions failed., nvinfer error:NVDSINFER_RESOURCE_ERROR
0:00:07.361913367 2144239 0x3e79ad0 ERROR nvinferserver gstnvinferserver.cpp:407:gst_nvinfer_server_logger:<secondary_inference_inference> nvinferserver[UID 10]: Error in initialize() <infer_base_context.cpp:84> [UID = 10]: Infer context faied to initialize inference information, nvinfer error:NVDSINFER_RESOURCE_ERROR
0:00:07.361922991 2144239 0x3e79ad0 WARN nvinferserver gstnvinferserver_impl.cpp:588:start:<secondary_inference_inference> error: Failed to initialize InferTrtIsContext
RTX A4000
• DeepStream Version
6.2 (Using docker image)
• TensorRT Version
Triton Server 23.03
Latest
The API call failed because it was unable to allocate enough memory or other resources to perform the requested operation.
Is there a memory leak or out of bounds in your preprocessing?
This may simply be because O0 has not optimized the code
Without code change using prebuilt nvinferserver lib.plugin it works.
Without code change rebuilding nvinferserver lib from source, it fails. (except O0)
I don’t think this is related to my preprocessing.
I will look into this issue.
I used nvcr.io/nvidia/deepstream:6.2-triton and tested deepstream-test1 and deepstream-lidar-inference-app.
No matter whether I recompile nvinferserver or not, they can run normally.
Have you installed other triton server versions? The default trition version in docker is 2.26.0.
It is recommended that you use the default trition version in docker
All my pipelines work if I don’t use extraInputProcess feature in nvinferserver. Can you try with that?
I tried TritonOnnxYolo(/opt/nvidia/deepstream/deepstream-6.2/sources).
This model uses extraInputProcess and it works fine.
By the way, do you have multiple GPUs?
If I am on a multi-GPUs server and add --gpus all when starting docker, a video memory error will be prompted.
CUDA failure 700: an illegal memory access was encountered
You can solve the issue by specifying the GPU with the following command.
export CUDA_VISIBLE_DEVICES=1
Can you share a sample to reproduce this issue?
