Building RAG Agents for LLMs DLI Course assessment
Hi, I’ve been doing the assessment, but once I run evaluation I keep getting this error:
Gradio Stream failed: Server error ‘500 Internal Server Error’ for url ‘http://lab:9012/retriever/stream
For more information check: 500 Internal Server Error - HTTP | MDN
And in the 09_langserve notebook I get this error:
INFO: 172.18.0.10:37022 - “POST /retriever/stream HTTP/1.1” 500 Internal Server Error
ERROR: Exception in ASGI application
File “/usr/local/lib/python3.11/site-packages/pydantic/v1/main.py”, line 716, in validate
value_as_dict = dict(value)
ValueError: dictionary update sequence element #0 has length 1; 2 is required
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.11/site-packages/uvicorn/protocols/http/httptools_impl.py”, line 411, in run_asgi
result = await app( # type: ignore[func-returns-value]
File “/usr/local/lib/python3.11/site-packages/uvicorn/middleware/proxy_headers.py”, line 69, in call
return await self.app(scope, receive, send)
File “/usr/local/lib/python3.11/site-packages/fastapi/applications.py”, line 1054, in call
await super().call(scope, receive, send)
File “/usr/local/lib/python3.11/site-packages/starlette/applications.py”, line 123, in call
await self.middleware_stack(scope, receive, send)
File “/usr/local/lib/python3.11/site-packages/starlette/middleware/errors.py”, line 186, in call
raise exc
File “/usr/local/lib/python3.11/site-packages/starlette/middleware/errors.py”, line 164, in call
await self.app(scope, receive, _send)
File “/usr/local/lib/python3.11/site-packages/starlette/middleware/exceptions.py”, line 65, in call
await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send)
File “/usr/local/lib/python3.11/site-packages/starlette/_exception_handler.py”, line 64, in wrapped_app
raise exc
File “/usr/local/lib/python3.11/site-packages/starlette/_exception_handler.py”, line 53, in wrapped_app
await app(scope, receive, sender)
File “/usr/local/lib/python3.11/site-packages/starlette/routing.py”, line 756, in call
File “/usr/local/lib/python3.11/site-packages/starlette/routing.py”, line 776, in app
await route.handle(scope, receive, send)
File “/usr/local/lib/python3.11/site-packages/starlette/routing.py”, line 297, in handle
File “/usr/local/lib/python3.11/site-packages/starlette/routing.py”, line 77, in app
await wrap_app_handling_exceptions(app, request)(scope, receive, send)
raise exc
File "/usr/local/lib/python3.11/site-packages/starlette/exception_handler.py", line 53, in wrapped_app
File “/usr/local/lib/python3.11/site-packages/starlette/routing.py”, line 72, in app
response = await func(request)
File “/usr/local/lib/python3.11/site-packages/fastapi/routing.py”, line 278, in app
raw_response = await run_endpoint_function(
File “/usr/local/lib/python3.11/site-packages/fastapi/routing.py”, line 191, in run_endpoint_function
return await dependant.call(**values)
File “/usr/local/lib/python3.11/site-packages/langserve/server.py”, line 582, in stream
return await api_handler.stream(request)
File “/usr/local/lib/python3.11/site-packages/langserve/api_handler.py”, line 1086, in stream
config, input
= await self._get_config_and_input(
File “/usr/local/lib/python3.11/site-packages/langserve/api_handler.py”, line 778, in get_config_and_input
input
= schema.validate(body.input)
File “/usr/local/lib/python3.11/site-packages/pydantic/v1/main.py”, line 718, in validate
raise DictError() from e
pydantic.v1.errors.DictError: value is not a valid dict
I can’t wrap my head around what’s going on, can somebody explain what did I do wrong?
