i was trying to compile my windows project on Linux to test speed differences, so i ended using C::B because the CUDA guide for Eclipse was totally outdated… (sdk 1.0)
Anyway i found a really good tutorial there:
http://benbarsdell.blogspot.com/2009/03/cu…ngs-second.html
but i followed all the instructions correctly, and it won’t work… i get these errors, for each *.cu file:
Compiling: cuda/BlurKernel.cu
g++: /media/disco_dati/DEV/CRender/cuda/BlurKernel.cu: linker input file unused because linking not done
Compiling: cuda/LightingKernels.cu
g++: /media/disco_dati/DEV/CRender/cuda/LightingKernels.cu: linker input file unused because linking not done
Compiling: cuda/LowRangeKernel.cu
g++: /media/disco_dati/DEV/CRender/cuda/LowRangeKernel.cu: linker input file unused because linking not done
Compiling: cuda/Rasterizer.cu
g++: /media/disco_dati/DEV/CRender/cuda/Rasterizer.cu: linker input file unused because linking not done
Linking console executable: bin/linux/Debug/CRender
g++: bin/Debug/cuda/BlurKernel.o: No file o directory
g++: bin/Debug/cuda/LightingKernels.o: No file or directory
g++: bin/Debug/cuda/LowRangeKernel.o: No file or directory
g++: bin/Debug/cuda/Rasterizer.o: No file or directory
Process terminated with status 1 (0 minutes, 0 seconds)
0 errors, 0 warnings
It looks exactly like if it is not using NVCC at all…
any ideas?
