I use NVIDIA hardware decoding in thread, but it did not release the graphics memory properly
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hardware Platform: gpu
nvidia A40 Driver Version: 510.85.02
issue Type is questions
gstreamer version: 1.22.7
i released gpu memory , when I encountered rtsp GST_MESSAGE_EOS, but it seems not work,
How did you confirm it did not release the graphics memory properly
I initialize the nvh264dec decoder, create several thread to decode the RTSP video stream. When encountering eos, I close the pipeline, but the gpu memory is not released
From nvidia-smi, it can be seen that the gpu memory continues to rise
This is DeepStream SDK forum. Because you are using the standard gstreamer plugin, it is recommended that you go to the Gstreamer forum to file this issue. Thanks
