Exactly one year ago I used the current at the time CUDA version (don’t remember which one) and I wrote some CUDA kernels that made use of my vector class. This class has some functions, mostly overloaded operators. And they all worked fine. But today I downloaded that newest CUDA toolkit, try to compile my old project and…
error: calling a host function("vec3::operator +") from a __device__/__global__ function("rasterizePixel") is not allowed
Is there a way to fix that? And I would prefer a way that avoids any modifications to vec3 class.
I have a same problem when I tried to compile julia_gpu.cu (cuda_by_example/chapter04) with CUDA 7.5
Since Cuda By Example is a very old textbook, I guess CUDA of higher version has changed a lot and is not compatible with the old codes in the textbook.
