Greetings to all people here!
Recently, I tried to search/find a way to solve large sparse linear Ax=b systems using CUDA library routines.
The sparse linear system is part of a Computational Fluid Dynamics solver and can be quite large.
For a modest computational mesh of 5million nodes, and by having 5 Navier-Stokes equations for each node, a 25mil x 25mil A matrix is formed.
Thus, direct and dense solutions are out of the question.
Matrix A is always square and the diagonal is always non-zero.
The current solution process for the linear system is a good old iterative Jacobi kernel (corresponding to computational nodes or cells in the CFD solver), which is easy to implement and debug, but has kinda bad convergence properties.
I was searching for something better.
I stumbled upon the cuSolverSp library, but I cannot seem to find any CUDA-Fortran examples to help me implement/adjust it for my case and setup.
Moreover, when I include -cudalib=cusolver in my Makefile, the compilation complains that it cannot find the relevant module.
For context, I already utilize -cudalib=cublas for parallel reduction and everything compiles and runs fine.
Is cuSolver available for CUDA-Fortran?
Is there a sparse linear system example I can use?
I am familiar with CSR format, since I also utilize it to solve the linear system using the PETSc library.
However, I am not entirely familiar with the CUDA handles and the corresponding API and I was hoping for a simple example that can guide me.
The example folders that come bundled with the HPC-SDK do not have any cuSolver examples for CUDA-Fortran.
What options do I have?
Best regards,
Konstantinos
