CAM_I2C bus to multiple cameras feasible on JETSON TX2?
Hi there,
Would like to get some advice on I2C connectivity for JETSON TX2.
I would like to build a camera interposer board that houses 3 cameras. Each of them have different I2C address.
I plan to just use the CAM_I2C_SCL/SDA bus and fanout to all 3 of them.
Is it feasible to fanout JETSON I2C bus to 3 cameras like this?
If the cameras have different I2C addresses, then yes, it should be possible to talk to them separately, one at a time, using the same I2C bus.
(At least according to my reading of the design docs.)
@cwz9000
snarky is right, and if your sensor address can’t programing you need an I2C Mux for multiple sensor design.
Cool,
Thanks guys for your feedback!
