tegra_sinterface = "serial_c"
After installing the above modified user, the problem still exists.
[ 850.448199] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 850.457340] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 850.467953] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 850.475670] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 850.486337] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 850.494053] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 850.504805] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 853.040197] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 853.049342] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 853.059932] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 853.067644] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 853.078295] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 853.086011] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 853.096718] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
trace.txt (4.2 KB)
dmesg.txt (79.9 KB)
dts.txt (413.7 KB)
tegra234-camera-ar0233-max96712-2lan-port2-1Cam.dtsi.txt (8.9 KB)
Because the speed is not enough, we can only roughly capture the waveform.
LAN0:
LAN1:
CLK LAN:
