I have a problem with my Sony IMX567 sensor. The sensor is working when I boost clocks with
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
But the sensor is not working without it. I receive this with noise:
This same sensor was working with a Jetson Nano without boosting clocks.
Do you have some idea about the cause of this ?
I made some tests. At boot, I have
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/vi/rate
832000000
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/isp/rate
1011200000
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
428600000
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate
832000000
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate
1011200000
root@ubuntu:/home/nvidia# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate
642900000
If I only do the command echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
, it’s working. I tested others commands and it seems that only this one is working.
Thank you
