We are developing GMSL camera driver on Orin NX, and encountered the following problems,please help to troubleshoot.
- If two 8M cameras are connected to the same mipi csi (4 lanes), the deserializer is configured with mipi lane rate of 2.0 Gbps, and the camera can output images normally.
- If two 8M cameras and one 2M camera are connected to the same mipi csi (4 lanes), the deserializer is configured with mipi lane rate of 2.4 Gbps, and the camera cannot output images.
Execute the following command to increase the rate
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
The trace log error is as follows:
kworker/0:2-96 [000] .... 1208.560859: rtcpu_nvcsi_intr: tstamp:38329997936 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560859: rtcpu_nvcsi_intr: tstamp:38329997936 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/0:2-96 [000] .... 1208.560859: rtcpu_nvcsi_intr: tstamp:38329998428 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560860: rtcpu_nvcsi_intr: tstamp:38329998762 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560860: rtcpu_nvcsi_intr: tstamp:38329998762 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000040
kworker/0:2-96 [000] .... 1208.560860: rtcpu_nvcsi_intr: tstamp:38329999255 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560860: rtcpu_nvcsi_intr: tstamp:38329999588 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560861: rtcpu_nvcsi_intr: tstamp:38329999588 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000040
kworker/0:2-96 [000] .... 1208.560861: rtcpu_nvcsi_intr: tstamp:38330000080 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560861: rtcpu_nvcsi_intr: tstamp:38330000414 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560861: rtcpu_nvcsi_intr: tstamp:38330000414 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000040
kworker/0:2-96 [000] .... 1208.560861: rtcpu_nvcsi_intr: tstamp:38330000910 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330001244 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330001244 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330001738 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330002074 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330002074 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000040
kworker/0:2-96 [000] .... 1208.560862: rtcpu_nvcsi_intr: tstamp:38330002564 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560863: rtcpu_nvcsi_intr: tstamp:38330002897 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
kworker/0:2-96 [000] .... 1208.560863: rtcpu_nvcsi_intr: tstamp:38330002897 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000044
