we are seeing the 49.7-day “Camera RTCPU gone bad” failure on Jetson Xavier NX, L4T 35.6.0
2025-12-02T00:45:14.093389+00:00 ivii-iriis-232240000770 kernel: \[4295040.231028\] tegra186-cam-rtcpu bc00000.rtcpu: Alert: Camera RTCPU gone bad! restoring it immediately
Kernel timestamp at failure is ~4295000s, i.e. the 2^32ms rollover — the same root cause as in these threads:
The answer given there was: fixed in JetPack 6.2.2 / L4T 36.5.0, no patch for r35. But Xavier NX cannot move to JetPack 6 — T194 is not supported there. That leaves us with a device family where a known, reproducible failure has no fix path at all.
So, concretely:
- Is there any JetPack 5 / L4T 35.x release in which this is fixed for T194? A yes or no is enough to unblock our planning.
- If no: is a patched camera-rtcpu-t194-rce.img planned, and on what timeline? We are happy to validate a test binary in a 60-day run.
- If it is won’t-fix for T194, please say so explicitly and add it to the L4T 35.x release notes as a known issue. It is not documented anywhere today, and we only discovered it after a unit failed in the field.
We have units in production and need to know whether to plan mandatory reboots below 49 days or wait for a firmware fix.
