We can’t load our own *.TRT engine files into deepstream. We want to ask if 3.0 deepstream can support 5.0.2.6 engine files.
I use tenosrrt5.0 to generate a yolov3.trt in python, but not work in deepstream3.0
Deepstream 3.0 is verified with JetPack4.1.1, which is 5.0.3.
May I know what kind of error do you meet?
Suppose the engine generated from TensorRT 5.0 should work fine with Deepstream3.0.
Please noticed that TensorRT engine cannot be used cross-platform.
You will need to generate the engine directly from the Xavier.
python==3.5.6;tensorrt==5.0.2.6(or)5.1.5.0;code==
(exclude front)
print(‘build_cuda_engine…’)
t = time()
with open(‘my_trt.trt’, ‘rb’) as f, trt.Runtime(logger) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
t = time() - t
print(‘finish! cost(seconds):’, t)
t = time()
with open(‘resnet10.caffemodel_b4_int8.engine’, ‘rb’) as f, trt.Runtime(logger) as runtime:
t = time() - t
(end)
terminal==
(exclude front)
build_cuda_engine…
[TensorRT] WARNING: TensorRT was compiled against cuDNN 7.5.0 but is linked against cuDNN 7.1.4
finish! cost(seconds): 2.6789138317108154
build_cuda_engine…
Process finished with exit code -1
(end)
‘resnet10.caffemodel_b4_int8.engine’ is generated by ‘resnet10.caffemodel’ from sample of deepstream==3.0
We don’t know the output shape of ‘resnet10.caffemodel’, we try to use our own model ‘yolov3.trt’
This is our ‘config_infer_primary.txt’:
(exclude front)
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#model-file=…/…/models/Primary_Detector/resnet10.caffemodel
#proto-file=…/…/models/Primary_Detector/resnet10.prototxt
#model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
model-engine-file=…/…/models/Primary_Detector/my_trt.trt
(exclude bottom)
terminal==
(deepstream-app:11181): GStreamer-CRITICAL **: 17:04:04.411: passed ‘0’ as denominator for `GstFraction’
Using TRT model serialized engine /home/linux/tool/deepstream/deepstream/DeepStreamSDK-Tesla-v3.0/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Primary_Detector/my_trt.trt crypto flags(0)
The engine plan file is incompatible with this version of TensorRT, expecting 5.0.2.6got 5.1.5.0, please rebuild.
Warning. Cannot use engine file /home/linux/tool/deepstream/deepstream/DeepStreamSDK-Tesla-v3.0/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Primary_Detector/my_trt.trt
Error. Cannot use engine file and model files not specified
** ERROR: main:564: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie_classifier: Failed to initialize infer context
Debug info: gstnvinfer.c(2141): gst_nv_infer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
App run failed
[1] + Done /usr/bin/gdb --interpreter=mi --tty=${DbgTerm} 0</tmp/Microsoft-MIEngine-In-wjxop010.w2x 1>/tmp/Microsoft-MIEngine-Out-8l0g1nvo.3yx
The issue is not from the TensorRT but cuDNN.
The model is broken due to cuDNN incompatibility.
There are lots of dependencies among driver, CUDA, cuDNN and TensorRT.
Do you still have the caffemodel/prototxt files?
It’s recommended to recompile a TensorRT engine each time the environment/device/software is updated.
ok
