I’ve pulled the deepstream:4.0.2-19.12-devel container and from it I built a new container strating from it where I have installed the Python bindings according to the HOWTO in GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications.
I am running the container with the following command where test_deeptstream_build is the container i’ve built:
docker run --gpus all -it --rm -p 8554:8554 -w /root test_deepstream_build:latest
I changed the ‘sink’ to ‘fakesink’ in the pipeline in deepstream_test_1.py.
To run I use the next command: python3 deepstream_test_1.py rtsp://[link]
I get the following error:
0:00:01.000833168 17 0xfbbd0a0 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.585835799 17 0xfbbd0a0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.)
0:00:01.586004949 17 0xfbbd0a0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): …/rtSafe/safeContext.cpp (105) - Cudnn Error in initializeCommonContext: 4 (Could not initialize cudnn, please check cudnn installation.)
0:00:01.586039349 17 0xfbbd0a0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Failed while building cuda engine for network
0:00:01.586180169 17 0xfbbd0a0 ERROR nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:01.586217909 17 0xfbbd0a0 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:01.586224679 17 0xfbbd0a0 WARN nvinfer gstnvinfer.cpp:692:gst_nvinfer_start: error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_TENSORRT_ERROR
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
root@c8d48ff90de9:~# ls -l /usr/local/cuda
lrwxrwxrwx 1 root root 9 Aug 26 2019 /usr/local/cuda -> cuda-10.1
The Dockerfile for the new container:
FROM nvcr.io/nvidia/deepstream:4.0.2-19.12-devel
ADD python_release_bind /root/deepstream_sdk_v4.0.2_x86_64/sources/python
RUN ls /app
RUN apt-get update -y
RUN apt-get install python-gi-dev -y
RUN export GST_LIBS="-lgstreamer-1.0 -lgobject-2.0 -lglib-2.0"
RUN export GST_CFLAGS="-pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include"
RUN apt-get install git -y
RUN cd /app/panel_factory/research/deepstream
RUN git clone https://github.com/GStreamer/gst-python.git
RUN cd gst-python && \
git checkout 1a8f48a && \
apt-get install autoconf automake libtool python-dev python3-dev libgstreamer1.0-dev -y && \
./autogen.sh PYTHON=python3 && \
./configure PYTHON=python3 && \
make &&\
make install
EXPOSE 8554
RUN ls root/deepstream_sdk_v4.0.2_x86_64/sources
RUN ls root/deepstream_sdk_v4.0.2_x86_64/sources/python
I tried your dockerfile as below, I can’t reproduce your issue.
Build the docker
$ docker build -t mchi_ds_test_docker --network=host .
docker file (referring to your dockerfile)
#RUN ls /app
RUN mkdir -p /app/panel_factory/research/deepstream
make &&\
make install
EXPOSE 8554
RUN ls /root/deepstream_sdk_v4.0.2_x86_64/sources
RUN ls /root/deepstream_sdk_v4.0.2_x86_64/sources/python
Launch the docker
$ docker run --gpus all -it --rm -p 8554:8554 -w /root mchi_ds_test_docker
Operate in docker
1). change “sink = Gst.ElementFactory.make(“nveglglessink”, “nvvideo-renderer”)” to “sink = Gst.ElementFactory.make(“fakesink”, “fakesink”)”
2). run
root@72df2daef6ea:~/deepstream_sdk_v4.0.2_x86_64/sources/python/apps/deepstream-test1# python3 deepstream_test_1.py /root/deepstream_sdk_v4.0.2_x86_64/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /root/deepstream_sdk_v4.0.2_x86_64/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Creating LL OSD context new
0:00:00.500260585 161 0x1a68190 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:09.939989665 161 0x1a68190 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /root/deepstream_sdk_v4.0.2_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
Frame Number=0 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=1 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=2 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=3 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=4 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=5 Number of Objects=6 Vehicle_count=4 Person_count=2
Frame Number=6 Number of Objects=5 Vehicle_count=3 Person_count=2
Frame Number=7 Number of Objects=6 Vehicle_count=4 Person_count=2
Okay, thanks for trying it. It also works on my side with the sample video. Then I guess the issue might be from trying to run the test app with an RSTP stream. Do you know if there’s something else that needs to be changed in order to use an RSTP stream?
I don’t think it caused by file source, i.t. RTSP since the failure is about cuDNN.
And, I tried with RTSP, it can build the TensorRT engine successfully as below.
Are you using the default model/engine or your own model/engine?
Playing file rtsp://freja.hiof.no:1935/rtplive/definst/hessdalen03.stream
Starting pipeline
0:00:00.494395481 289 0x272b990 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:09.998787402 289 0x272b990 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /root/deepstream_sdk_v4.0.2_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
Error: gst-resource-error-quark: Resource not found. (3): gstfilesrc.c(533): gst_file_src_start (): /GstPipeline:pipeline0/GstFileSrc:file-source:
No such file “rtsp://freja.hiof.no:1935/rtplive/definst/hessdalen03.stream”
root@72df2daef6ea:~/deepstream_sdk_v4.0.2_x86_64/sources/python/apps/deepstream-test1# ls -l /root/deepstream_sdk_v4.0.2_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
-rw-r–r-- 1 root root 4405865 Mar 6 08:10 /root/deepstream_sdk_v4.0.2_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
I am using the default model.
I managed to get it to run just like your example above and just like you I get the next error:
No such file "rtsp://admin:Hik.1234567890@1[IP]/cam/realmonitor?channel=1"
I checked the RSTP stream with VLC and it works, it is correctly streaming, and I do have response when I ping the camera’s IP from the running container.
I don’t think so, but you can change “sink = Gst.ElementFactory.make(“nveglglessink”, “nvvideo-renderer”)” to “sink = Gst.ElementFactory.make(“fakesink”, “fakesink”)”
