Does anyone have experience or insight in applying AR/SR/Upscale filter in real time? Is this possible? What what I can tell, AR is possible, but not sure about SR/Upscale.
Hello!
Yes, both of these can be run in real-time (Artifact Reduction and Upscale/Super Resolution). Upscale is lighter in the processing and you can run multiple streams simultaneously. With Super Resolution you should be able to run a stream in real-time depending on your hardware and the resolution. There is a mode setting for Super Resolution that includes the artifact reduction and Super Resolution. If you have heavily processed/artifacted videos with big block artifacts and/or banding, I would recommend using that mode. If you have clean video, such as from a webcam or high quality video source, you may want to just run the super resolution or upscale. You might also consider the denoising, if you’re seeing noise in the video.
