thank you!
but I got seg fault result in tensorNet’s caffeToTRTModel method.
----------LOG----------------
outputs size : 23
blobNameToTensor : relu1
blobNameToTensor : relu2
blobNameToTensor : relu3
blobNameToTensor : relu4
blobNameToTensor : relu5
blobNameToTensor : relu6
blobNameToTensor : relu7
blobNameToTensor : relu8
blobNameToTensor : relu9
blobNameToTensor : relu10
blobNameToTensor : relu11
blobNameToTensor : relu12
blobNameToTensor : relu13
blobNameToTensor : relu14
blobNameToTensor : relu15
blobNameToTensor : relu16
blobNameToTensor : relu17
blobNameToTensor : relu18
blobNameToTensor : relu19
blobNameToTensor : relu20
blobNameToTensor : relu21
blobNameToTensor : relu22
blobNameToTensor : reorg1
----------tensorNet.cpp CODE----------------
[/b]
[b]printf("outputs size : %d\n",outputs.size());
for (auto& s : outputs) {
printf("blobNameToTensor : %s\n",s.c_str());
[u]network->markOutput(*blobNameToTensor->find(s.c_str()));[/u]
[/b]
there are 22 relu layers…can you guess where I missed?
the error seems to occur in makring the output of relu3 plugin layer…
I set the output dimension of leaky relu as
DimsCHW(inputs[0].d[0], inputs[0].d[1], inputs[0].d[2]);
and I set the output dim of reorg as
DimsCHW(256, 19, 19); // this is right for 608x608 input.
hum…I think I should show you all of my code as below;;
------------------------------------------pluginImplement.h-------------------------------------------
using namespace nvinfer1;
using namespace nvcaffeparser1;
using namespace plugin;
class LeakyReLULayer : public IPlugin
public:
LeakyReLULayer() {};
LeakyReLULayer(const void* buffer, size_t size);
inline int getNbOutputs() const override { return 1; };
Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override;
int initialize() override;
inline void terminate() override { ; }
inline size_t getWorkspaceSize(int) const override { return 0; }
int enqueue(int batchSize, const void*const *inputs, void** outputs, void*, cudaStream_t stream) override;
size_t getSerializationSize() override;
void serialize(void* buffer) override;
void configure(const Dims*inputs, int nbInputs, const Dims* outputs, int nbOutputs, int) override;
protected:
DimsCHW dimsSrc;
class ReorgLayer : public IPlugin
public:
ReorgLayer() {};
ReorgLayer(const void* buffer, size_t size);
protected:
DimsCHW dimsSrc;
class PluginFactory : public nvinfer1::IPluginFactory, public nvcaffeparser1::IPluginFactory
public:
virtual nvinfer1::IPlugin* createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights) override;
IPlugin* createPlugin(const char* layerName, const void* serialData, size_t serialLength) override;
bool isPlugin(const char* name) override;
void destroyPlugin();
std::unique_ptr<LeakyReLULayer> mLeakyReLULayer[22] {nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr};
std::unique_ptr<ReorgLayer> mReorgLayer{ nullptr };
#endif
------------------------------------------pluginImplement.c-------------------------------------------
#include <pluginImplement.h>
// PluginFactory
//typedef std::unique_ptr LeakyReLULayerPtr;
//LeakyReLULayerPtr mLeakyReLULayer[22] {nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr, nullptr, nullptr, nullptr,nullptr, nullptr};
int mReluCount = 0;
// allocate elements with this:
nvinfer1::IPlugin* PluginFactory::createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights)
printf(“NV IPlugin layerName : %s \n”,layerName);
assert(isPlugin(layerName));
if( !strcmp(layerName, "relu1")
|| !strcmp(layerName, "relu2")
|| !strcmp(layerName, "relu3")
|| !strcmp(layerName, "relu4")
|| !strcmp(layerName, "relu5")
|| !strcmp(layerName, "relu6")
|| !strcmp(layerName, "relu7")
|| !strcmp(layerName, "relu8")
|| !strcmp(layerName, "relu9")
|| !strcmp(layerName, "relu10")
|| !strcmp(layerName, "relu11")
|| !strcmp(layerName, "relu12")
|| !strcmp(layerName, "relu13")
|| !strcmp(layerName, "relu14")
|| !strcmp(layerName, "relu15")
|| !strcmp(layerName, "relu16")
|| !strcmp(layerName, "relu17")
|| !strcmp(layerName, "relu18")
|| !strcmp(layerName, "relu19")
|| !strcmp(layerName, "relu20")
|| !strcmp(layerName, "relu21")
|| !strcmp(layerName, "relu22")){
printf("NV IPlugin mReluCount : %d \n",mReluCount);
//assert(mReluCount <22);
assert(mLeakyReLULayer[mReluCount].get() == nullptr);
mLeakyReLULayer[mReluCount] = std::unique_ptr<LeakyReLULayer>(new LeakyReLULayer());
//mLeakyReLULayer[mReluCount] = LeakyReLULayerPtr();
return mLeakyReLULayer[mReluCount++].get();
else if(!strcmp(layerName, "reorg1")){
printf("NV IPlugin reorg1 \n");
assert(mReorgLayer.get() == nullptr);
mReorgLayer= std::unique_ptr<ReorgLayer>(new ReorgLayer());
return mReorgLayer.get();
else
printf("NV NOT VALID PLUG IN LAYER \n");
assert(0);
return nullptr;
IPlugin* PluginFactory::createPlugin(const char* layerName, const void* serialData, size_t serialLength)
printf(“IPlugin layerName : %s \n”,layerName);
printf("IPlugin mReluCount : %d \n",mReluCount);
//mLeakyReLULayer[mReluCount] = LeakyReLULayerPtr(serialData, serialLength);
mLeakyReLULayer[mReluCount] = std::unique_ptr<LeakyReLULayer>(new LeakyReLULayer(serialData, serialLength));
printf("IPlugin reorg1 \n");
mReorgLayer= std::unique_ptr<ReorgLayer>(new ReorgLayer(serialData, serialLength));
else
{ printf("NOT VALID PLUG IN LAYER \n");
assert(0);
return nullptr;
bool PluginFactory::isPlugin(const char* name)
if (!strcmp(name, “relu1”)
|| !strcmp(name, “relu2”)
|| !strcmp(name, “relu3”)
|| !strcmp(name, “relu4”)
|| !strcmp(name, “relu5”)
|| !strcmp(name, “relu6”)
|| !strcmp(name, “relu7”)
|| !strcmp(name, “relu8”)
|| !strcmp(name, “relu9”)
|| !strcmp(name, “relu10”)
|| !strcmp(name, “relu11”)
|| !strcmp(name, “relu12”)
|| !strcmp(name, “relu13”)
|| !strcmp(name, “relu14”)
|| !strcmp(name, “relu15”)
|| !strcmp(name, “relu16”)
|| !strcmp(name, “relu17”)
|| !strcmp(name, “relu18”)
|| !strcmp(name, “relu19”)
|| !strcmp(name, “relu20”)
|| !strcmp(name, “relu21”)
|| !strcmp(name, “relu22”)
|| !strcmp(name, “reorg1”)){
//printf(" Layer Name : %s \n",name);
return true;
else{
return false;
void PluginFactory::destroyPlugin()
for(int i=0; i<22; i++){
mLeakyReLULayer[i].release();
mLeakyReLULayer[i] = nullptr;
mReorgLayer.release();
mReorgLayer = nullptr;
// LeakyReLULayer Plugin Layer
//void convertROI(float* input, float* output, char* mean, const int* srcSize, const int* dstSize, const int* roi, cudaStream_t stream);
void leakyrelu_gpu(float* input, int * srcSize, float* output, cudaStream_t stream);
LeakyReLULayer::LeakyReLULayer(const void* buffer, size_t size)
printf(" LeakyReLULayer Constructor \n");
assert(size==(3sizeof(int)));
const int d = reinterpret_cast<const int*>(buffer);
dimsSrc = DimsCHW{d[0], d[1], d[2]};
Dims LeakyReLULayer::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
printf(" LeakyReLULayer getOutputDimensions → nbInputDims: %d\n",nbInputDims);
assert(nbInputDims==1);
return DimsCHW(inputs[0].d[0], inputs[0].d[1], inputs[0].d[2]);
int LeakyReLULayer::initialize()
printf(" LeakyReLULayer initialize \n");
return 0;
int LeakyReLULayer::enqueue(int batchSize, const voidconst inputs, void* outputs, void, cudaStream_t stream)
printf(" LeakyReLULayer enqueue \n");
int srcSize {dimsSrc.c(), dimsSrc.h(), dimsSrc.w()};
leakyrelu_gpu((float*)inputs[0], srcSize, (float*)outputs[0],stream);
return 0;
size_t LeakyReLULayer::getSerializationSize()
printf(" LeakyReLULayer getSerializationSize \n");
return 3*sizeof(int);
void LeakyReLULayer::serialize(void* buffer)
printf(" LeakyReLULayer serialize \n");
int* d = reinterpret_cast<int*>(buffer);
d[0] = dimsSrc.c(); d[1] = dimsSrc.h(); d[2] = dimsSrc.w();
void LeakyReLULayer::configure(const Dimsinputs, int nbInputs, const Dims outputs, int nbOutputs, int)
printf(" LeakyReLULayer configure \n");
dimsSrc = DimsCHW{inputs[0].d[0], inputs[0].d[1], inputs[0].d[2]};
// ReorgLayer Plugin Layer
void reorg_gpu(float* input, int * srcSize, int* dstSize, float* output, cudaStream_t stream);
ReorgLayer::ReorgLayer(const void* buffer, size_t size)
printf(" ReorgLayer Constructorn");
//dimsConf = DimsCHW{d[3], d[4], d[5]};
//dimsBbox = DimsCHW{d[6], d[7], d[8]};
Dims ReorgLayer::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
printf(" ReorgLayer getOutputDimensions → nbInputDims: %d\n",nbInputDims);
return DimsCHW(256, 19, 19);
int ReorgLayer::initialize()
{ printf(" ReorgLayer initialize \n");
return 0;
int ReorgLayer::enqueue(int batchSize, const voidconst inputs, void* outputs, void, cudaStream_t stream)
printf(" ReorgLayer enqueue \n");
CHECK(cudaThreadSynchronize());
int srcSize[] {dimsSrc.w(), dimsSrc.h(), dimsSrc.c()};
int dstSize[] {19, 19, 256};
reorg_gpu((float*)inputs[0], srcSize, dstSize, (float*)outputs[0],stream);
return 0;
size_t ReorgLayer::getSerializationSize()
{ printf(" ReorgLayer getSerializationSize \n");
void ReorgLayer::serialize(void* buffer)
{ printf(" ReorgLayer serialize \n");
void ReorgLayer::configure(const Dimsinputs, int nbInputs, const Dims outputs, int nbOutputs, int)
{ printf(" ReorgLayer configure \n");
------------------------------------------tensorNet.cpp-------------------------------------------
void TensorNet::caffeToTRTModel(const std::string& deployFile,
const std::string& modelFile,
const std::vectorstd::string& outputs,
unsigned int maxBatchSize)
IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition* network = builder->createNetwork();
ICaffeParser* parser = createCaffeParser();
parser->setPluginFactory(&pluginFactory);
bool useFp16 = builder->platformHasFastFp16();
DataType modelDataType = useFp16 ? DataType::kHALF : DataType::kFLOAT;
const IBlobNameToTensor *blobNameToTensor = parser->parse(deployFile.c_str(),
modelFile.c_str(),
*network,
modelDataType);
assert(blobNameToTensor != nullptr);
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(16 << 20);
if(useFp16) builder->setHalf2Mode(true);
ICudaEngine* engine = builder->buildCudaEngine(*network);
assert(engine);
network->destroy();
parser->destroy();
gieModelStream = engine->serialize();
engine->destroy();
builder->destroy();
pluginFactory.destroyPlugin();
shutdownProtobufLibrary();
and the seg fault result is as below;
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1280, height=(int)720, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
successfully initialized video device
width: 1280
height: 720
depth: 24 (bpp)
loadLabelInfo
successfully load LabelInfo
NV IPlugin layerName : relu1
NV IPlugin mReluCount : 0
LeakyReLULayer getOutputDimensions → nbInputDims: 1
NV IPlugin layerName : relu2
NV IPlugin mReluCount : 1
NV IPlugin layerName : relu3
NV IPlugin mReluCount : 2
NV IPlugin layerName : relu4
NV IPlugin mReluCount : 3
NV IPlugin layerName : relu5
NV IPlugin mReluCount : 4
NV IPlugin layerName : relu6
NV IPlugin mReluCount : 5
NV IPlugin layerName : relu7
NV IPlugin mReluCount : 6
NV IPlugin layerName : relu8
NV IPlugin mReluCount : 7
NV IPlugin layerName : relu9
NV IPlugin mReluCount : 8
NV IPlugin layerName : relu10
NV IPlugin mReluCount : 9
NV IPlugin layerName : relu11
NV IPlugin mReluCount : 10
NV IPlugin layerName : relu12
NV IPlugin mReluCount : 11
NV IPlugin layerName : relu13
NV IPlugin mReluCount : 12
NV IPlugin layerName : relu14
NV IPlugin mReluCount : 13
NV IPlugin layerName : relu15
NV IPlugin mReluCount : 14
NV IPlugin layerName : relu16
NV IPlugin mReluCount : 15
NV IPlugin layerName : relu17
NV IPlugin mReluCount : 16
NV IPlugin layerName : relu18
NV IPlugin mReluCount : 17
NV IPlugin layerName : relu19
NV IPlugin mReluCount : 18
NV IPlugin layerName : relu20
NV IPlugin mReluCount : 19
NV IPlugin layerName : relu21
NV IPlugin mReluCount : 20
NV IPlugin layerName : reorg1
NV IPlugin reorg1
ReorgLayer getOutputDimensions → nbInputDims: 1
NV IPlugin layerName : relu22
NV IPlugin mReluCount : 21
outputs size : 23
I tried to debug it myself but I failed to find the cause of this error and where it is.
Please help me one more time;;;
Thank you!!
