Can I downgrade DGX SPARK to cuda 12?
My current software stack requires torch and torchaudio. CUDA13 requires torch v2.9. However, it keeps producing problematic audio when using torch v2.9, both with and without GPU enabled. When I switch to torch 2.8 CPU only, the generated audio sounds great. Torch 2.8 only supports CUDA 12, therefore, I couldn’t use the GPU on DGX SPARK if I have to use torch 2.8.
So I am wondering if SPARK can be downgrade to CUDA 12? I tried to uninstall CUDA13 and install CUDA 12, then Nvidia SMI no longer shows the GPU. When I tried to install the CUDA13 back, everything is broken.
dup Can I downgrade DGX SPARK to cuda 12? - #4 by mccormackjim3
