Can I downgrade DGX SPARK to cuda 12?
My current software stack requires torch and torchaudio. CUDA13 requires torch v2.9. However, it keeps producing problematic audio when using torch v2.9, both with and without GPU enabled. When I switch to torch 2.8 CPU only, the generated audio sounds great. Torch 2.8 only supports CUDA 12, therefore, I couldn’t use the GPU on DGX SPARK if I have to use torch 2.8.
So I am wondering if SPARK can be downgrade to CUDA 12? I tried to uninstall CUDA13 and install CUDA 12, then Nvidia SMI no longer shows the GPU. When I tried to install the CUDA13 back, everything is broken.
consider using CUDA 12.x based containers from GPU-optimized AI, Machine Learning, & HPC Software | NVIDIA NGC
this should not effect your native host software stack, including the GPU driver.
Thank you for the advice, I will try out the container approach.
Yes – I had to do container route to get indes2-tts running:
My Key Lessons Learned for IndexTTS on DGX Spark:
1. CUDA & PyTorch Compatibility
  • Use CUDA 12.9.0 with PyTorch 2.8.0 (test/cu129 channel)
  • Critical: Match exact CUDA version with PyTorch build
  • Command: pip3 install torch==2.8.0 torchaudio==2.8.0 --index-url https://download.pytorch.org/whl/test/cu129
2. Dependency Management
  • Install in correct order: System deps → PyTorch → Core ML → Audio processing → UI
  • Essential system packages: python3 python3-pip espeak-ng ffmpeg
  • Core ML stack: transformers==4.52.1 tokenizers==0.21.0 safetensors==0.5.2 accelerate==1.8.1
  • Audio processing: librosa==0.10.2.post1 soundfile numba==0.58.1
  • Web UI: gradio==5.45.0
Hi Maccormackjim3, I am doing IntexTTS on DGX too. Your input is real valuable to me. Thank you for sharing.
I finally got it working with the docker image. Have to spend quite a bit of time resolving the pynini package installation issue. Basically I have to install conda in the docker to get a working version of the pynini. And getting conda to activate the enviroment in docker is also not an easy task. Other than that, things are in order now and I can produce clear audio on SPARK.
Cheers
