Can I improve rendering time by switching from RTX 2060 to RTX5090 in THIS kind of project?
I need to create meditation sounds in 10 hours playlist.
  • I use Premiere Pro.
  • The only video track is the static business logo.
    • The only audio track is the music playlist
  • Export: H.264 1080p 30fps low bitrate
Using RTX2060 on a Core i7-7700 I can render this project in 30 minutes.
If I use RTX 5090 ( Core i9 - 14900k), can I render in much less time?
I need to know if i invest in a new PC prepared to RTX 5090 or I need other strategy.
Thank you.
  • This is my first time typing in a forum.
Yes, RTX 5090 + i9-14900K will render faster-likely under 10 minutes. Premiere Pro benefits from GPU and CPU upgrades. It’s a good investment if you render often.
