I got a RTX 5090 with 32GB VRAM at the GTX conference for $2k. I can purchase a RTX 6000 Pro with 96GB VRAM for about $6500-7500 and put in a server. Is this worth the $4k?
What is your use case?
Do you move around a lot? Do you want to carry a RTX 5090 or RTX 6000 Pro around w/ a power supply for an eGPU setup?
Do you have a DGX cluster already set up so you can do from Spark → Cluster?
But since you’re asking without any use case, yes you should probably get the 5090 or Pro 6000.
