Can I replace the libjpeg.so from sdk5.1.3 to 5.1.1
Continuing the discussion from NvJPEGEncoder function EncodeFromBuffer or EncodeFromFd memory usage is too high:
Because some devices have been delivered to customers. It’s different to update the sdk. Can I replace the libjpeg.so from sdk5.1.1 to 5.1.2 or 5.1.3??
It may not work to apply libnvjpeg.so from Jetpack 5.1.3(or 5.1.2) to 5.1.1. We would suggest upgrade the system. If you have to stay on 5.1.1, may consider use software encoder.
But software encoder is too slow. I need 32 pictures 1920X1080 a second.
You may need to recompile the bugfixed library from source on the target jetpack version in order to get all the references right.
As an alternative you may send out pre-flashed processor modules (with heatsink installed) to the affected customers and have them do the swap and send back the old module.
