can I use NVdecoder to decode the video with alpha channel and get RGBA images?
first i have a video with alpha channel, and the video is encoded by vp9, the container format is webm. than I use the ffmpeg to demux the the video. it’s ok! but when I use nvdecoder to decode the packet,I want to get the RGBA image for opengl display. the function Nv12ToBgra32 is not deal with the alpha channel. so how can I do to get RGBA format image or data?
Hi.
Video decode with alpha channel is not supported with NVIDIA Video Codec SDK.
thank you
I see the latest NVENC supports to encode alpha channel to HEVC.
However I could not find any information for alpha decoding using NVDEC.
Does the latest NVDEC support to decode HEVC with alpha channel already?
Thank you.
Theoretically yes, because vp9 uses completly separate bitstream for alpha. Even encoding stettings is separate for alpha. But not supported by nvidia apis.
