Hi PasToutSeul!
Thanks for your support. When I run
gst-launch-1.0 -v spinnakersrc ! videoconvert ! ximagesink
I get the following from the verbose bit:
nvidia@xavier-emb:~$ gst-launch-1.0 -v spinnakersrc ! videoconvert ! ximagesink
(gst-launch-1.0:10213): GStreamer-CRITICAL **: 11:12:17.716: gst_clock_get_time: assertion 'GST_IS_CLOCK (clock)' failed
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstSpinnakerSrc:spinnakersrc0.GstPad:src: caps = video/x-raw, format=(string)RGBA, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)BGRx
/GstPipeline:pipeline0/GstXImageSink:ximagesink0.GstPad:sink: caps = video/x-raw, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)BGRx
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)RGBA, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB, framerate=(fraction)0/1
When I run
gst-launch-1.0 -v spinnakersrc ! nvvidconv ! nvoverlaysink -e
I get
nvidia@xavier-emb:~$ gst-launch-1.0 -v spinnakersrc ! nvvidconv ! nvoverlaysink -e
nvbuf_utils: Could not get EGL display connection
(gst-launch-1.0:10560): GStreamer-CRITICAL **: 11:18:08.409: gst_clock_get_time: assertion 'GST_IS_CLOCK (clock)' failed
/GstPipeline:pipeline0/GstSpinnakerSrc:spinnakersrc0.GstPad:src: caps = video/x-raw, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA, colorimetry=(string)sRGB
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA
In gst_spinnaker_src_create:
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, width=(int)2736, height=(int)1824, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA, colorimetry=(string)sRGB
I somehow don’t think that the “nvbuf_utils: Could not get EGL display connection” is the problem, because I am also not able to do compression on the gpu, directly to a file. Any advice?
