Gstreamer is a really interesting framework, there exists almost nothing online because most of the information you need is accessible using the “gst-inspect” tool. The “caps” which you’ll hear reference to means that string of text you have between videotestsrc and nvvidconv. What that does is tell the thing on the left what it should source, and the thing on the right what it should sink. Both of those modules need have those options or else you get the erroneous pipeline error.
Here’s the result of inspecting nvvidconv. Take a look at the “SINK template,” I bolded it for reference. That’s everything nvvidconv will accept, notice RGB isn’t on the list for format.
ubuntu@tegra-ubuntu:~$ gst-inspect-1.0 nvvidconv
Factory Details:
Rank primary (256)
Long-name NvVidConv Plugin
Klass Filter/Converter/Video/Scaler
Description Converts video from one colorspace to another & Resizes
Author amit pandya <apandya@nvidia.com>
Plugin Details:
Name nvvidconv
Description video Colorspace conversion & scaler
Filename /home/ubuntu/gst_1.11.1/out/lib/gstreamer-1.0/libgstnvvidconv.so
Version 1.2.3
License Proprietary
Source module gstreamer-nvvconv-plugin
Binary package GStreamer nvvconv Plugin
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseTransform
+----Gstnvvconv
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { I420, UYVY, NV12, GRAY8, BGRx, RGBA }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
[b] SINK template: 'sink'
Capabilities:
video/x-raw
framerate: [ 0/1, 2147483647/1 ][/b]
Element Flags:
no flags set
Element Implementation:
Has change_state() function: 0x7f90901d78
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvvconv0"
parent : The parent of the object
Object of type "GstObject"
qos : Handle Quality-of-Service events
Boolean. Default: false
silent : Produce verbose output ?
flip-method : video flip methods
flags: readable, writable, controllable
Enum "GstNvVideoFlipMethod" Default: 0, "none"
(0): none - Identity (no rotation)
(1): counterclockwise - Rotate counter-clockwise 90 degrees
(2): rotate-180 - Rotate 180 degrees
(3): clockwise - Rotate clockwise 90 degrees
(4): horizontal-flip - Flip horizontally
(5): upper-right-diagonal - Flip across upper right/lower left diagonal
(6): vertical-flip - Flip vertically
(7): upper-left-diagonal - Flip across upper left/lower right diagonal
tnr : Temporal Noise Reduction
Enum "GstNvVideoTNRAlgos" Default: 0, "disabled"
(0): disabled - TNR Disabled
(1): original - TNR Original
(2): outdoor-low-light - TNR Outdoor Low light
(3): outdoor-medium-light - TNR Outdoor Medium Light
(4): outdoor-high-light - TNR Outdoor High Light
(5): indoor-low-light - TNR Indoor Low light
(6): indoor-medium-light - TNR Indoor Medium Light
(7): indoor-high-light - TNR Indoor High Light
output-buffers : number of output buffers
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Unsigned Integer. Range: 1 - 4294967295 Default: 4
interpolation-method: Set interpolation methods
Enum "GstInterpolationMethod" Default: 2, "Smart"
(0): Nearest - Nearest
(1): Linear - Linear
(2): Smart - Smart, this is default
(3): Bilinear - Bilinear
left : Pixels to crop at left
Integer. Range: 0 - 2147483647 Default: 0
right : Pixels to crop at right
top : Pixels to crop at top
bottom : Pixels to crop at bottom
Two issues I see. First you’re asking videotestsrc to source "video/x-raw(memory:NVMM) which it doesn’t understand. That’s just an Nvidia thing. Second you’re asking nvvidconv to sink format RGB which it doesn’t support.
Inspecting videotestsrc shows that it is capable of sourcing the following:
Pad Templates:
SRC template: 'src'
Capabilities:
video/x-raw
format: { I420, YV12, YUY2, UYVY, VYUY, AYUV, RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR, Y41B, Y42B, YVYU, Y444, v210, v216, NV12, NV21, NV16, NV61, NV24, GRAY8, GRAY16_BE, GRAY16_LE, v308, IYU2, RGB16, BGR16, RGB15, BGR15, UYVP, A420, RGB8P, YUV9, YVU9, IYU1, ARGB64, AYUV64, r210, I420_10LE, I420_10BE, I422_10LE, I422_10BE, Y444_10LE, Y444_10BE, GBR, GBR_10LE, GBR_10BE, NV12_64Z32, A420_10LE, A420_10BE, A422_10LE, A422_10BE, A444_10LE, A444_10BE, P010_10LE, P010_10BE }
video/x-bayer
format: { bggr, rggb, grbg, gbrg }
So we need to choose a format that can be handled by nvvidconv. Looks like your options are I420, UYVY, NV12, or RGBA.
Try this:
gst-launch-1.0 videotestsrc ! 'video/x-raw, format=(string)RGBA, width=(int)1504, height=(int)1504, framerate=(fraction)120/1' ! nvvidconv ! omxh264enc control-rate=2 bitrate=40000000 ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=$CLIENT_IP port=5000 sync=false async=false
