Jetson TK1 R21.5
“L4T_Jetson_TK1_Multimedia_User_Guide.R21.5_2016July06.pdf” says the gst-0.10 version nvvidconv supports sink “I420, YUY2, UYVY, YVYU, Y444, and NV12” which is verified by gst-inspect-0.10 nvvidconv:
ubuntu@tegra-ubuntu:~/w$ gst-inspect-0.10 nvvidconv
Factory Details:
Long name: NvVidConv Plugin
Class: Filter/Converter/Video
Description: Converts Video from Nv to raw/rgb formats & vice versa
Author(s): amit/anaken <<apandya@nvidia.com>>
Rank: primary (256)
Plugin Details:
Description: nvvidconv plugin
Filename: /usr/lib/arm-linux-gnueabihf/gstreamer-0.10/libgstnvvidconv.so
Version: 0.10.0
License: Proprietary
Source module: gstreamer-nvvconv-plug-ins
Binary package: GStreamer nvvconv Plug-ins
Origin URL: http://nvidia.com/
GObject
+----GstObject
+----GstElement
+----GstBaseTransform
+----GstVideoFilter
+----GstNvVConv
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw-yuv
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { I420, YUY2, UYVY, YVYU }
video/x-raw-rgb
bpp: 32
depth: 32
endianness: 4321
red_mask: 65280
green_mask: 16711680
blue_mask: -16777216
alpha_mask: 255
framerate: [ 0/1, 2147483647/1 ]
video/x-raw-rgb
bpp: 32
depth: 32
endianness: 4321
red_mask: -16777216
blue_mask: 65280
alpha_mask: 255
video/x-raw-rgb
bpp: 32
depth: 24
endianness: 4321
red_mask: 65280
video/x-raw-rgb
bpp: 32
depth: 24
endianness: 4321
red_mask: -16777216
blue_mask: 65280
video/x-raw-gray
bpp: 8
depth: 8
video/x-nv-yuv
format: { I420, NV12 }
video/x-nvrm-yuv
SINK template: 'sink'
Capabilities:
video/x-raw-yuv
format: { I420, YV12, YUY2, UYVY, YVYU, Y444, NV12 }
video/x-raw-gray
bpp: 8
depth: 8
video/x-nv-yuv
video/x-nvrm-yuv
Element Flags:
no flags set
Element Implementation:
Has change_state() function: 0xb6f88474
Has custom save_thyself() function: gst_element_save_thyself
Has custom restore_thyself() function: gst_element_restore_thyself
Element has no clocking capabilities.
Element has no indexing capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Implementation:
Has getrangefunc(): gst_base_transform_getrange
Has custom eventfunc(): gst_base_transform_src_event
Has custom queryfunc(): gst_base_transform_query
Provides query types:
(1): position (Current position)
Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
Has getcapsfunc(): gst_base_transform_getcaps
Has acceptcapsfunc(): gst_base_transform_acceptcaps
Pad Template: 'src'
SINK: 'sink'
Implementation:
Has chainfunc(): gst_base_transform_chain
Has custom eventfunc(): gst_base_transform_sink_event
Has bufferallocfunc(): gst_base_transform_buffer_alloc
Has setcapsfunc(): gst_base_transform_setcaps
Pad Template: 'sink'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvvconv0"
qos : Handle Quality-of-Service events
Boolean. Default: true
silent : Produce verbose output
Boolean. Default: false
That means gst-0.10 supports more formats compared to gst-1.0 which has only options of "I420, UYVY, NV12, GRAY8 ".
However, I have never realized format converting from any of “I420, YV12, YUY2, UYVY, YVYU, Y444, NV12” to “I420 or NV12” with scaling at the same time.
The following script fails:
GST_DEBUG=3 gst-launch-0.10 videotestsrc ! 'video/x-raw-yuv, width=(int)3840, height=(int)2160, format=I420' ! tee name=t ! queue ! nvvidconv ! 'video/x-nv-yuv, width=(int)1280, height=(int)720' ! nv_omx_h264enc ! 'video/x-h264, stream-format=(string)byte-stream, bitrate=9000000' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=10.10.80.7 port=5000 sync=true async=false t. ! queue ! nvvidconv ! 'video/x-nv-yuv, width=(int)1920, height=(int)1080' ! nv_omx_h264enc ! 'video/x-h264, stream-format=(string)byte-stream, bitrate=9000000' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=10.10.80.7 port=5002 sync=true
and fails for any replacement to format=I420 with any of "YV12, YUY2, UYVY, YVYU, Y444, NV12 ".
Whereas, the following script runs well:
GST_DEBUG=3 gst-launch-0.10 videotestsrc ! 'video/x-raw-yuv, width=(int)3840, height=(int)2160' ! tee name=t ! queue ! nvvidconv ! 'video/x-nv-yuv, width=(int)1280, height=(int)720' ! nv_omx_h264enc ! 'video/x-h264, stream-format=(string)byte-stream, bitrate=9000000' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=10.10.80.7 port=5000 sync=true async=false t. ! queue ! nvvidconv ! 'video/x-nv-yuv, width=(int)1920, height=(int)1080' ! nv_omx_h264enc ! 'video/x-h264, stream-format=(string)byte-stream, bitrate=9000000' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=10.10.80.7 port=5002 sync=true
The only difference is no “format=I420”, i.e. not specifying format for nnvidconv input.
I have no idea about how to get the real caps / limitations of nvidia proprietary gst plugins. Somebody have any suggestions?
