The GStreamer 1.0 plugins that support NVMM, provided by NVIDIA, have very wonky coupling.
First of all, I have a video file that is mjpeg in mkv. This is what FFmpeg 3.3.1 says about my file:
ubuntu@tegra-ubuntu:~$ ffmpeg -i output2.mkv
ffmpeg version 3.3.1 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.3)
configuration: --prefix=/home/ubuntu/ffmpeg_build --extra-cflags=-I/home/ubuntu/ffmpeg_build/include --extra-ldflags=-L/home/ubuntu/ffmpeg_build/lib --bindir=/home/ubuntu/bin --enable-gpl --enable-libx264 --enable-avresample --enable-nonfree --enable-shared
libavutil 55. 58.100 / 55. 58.100
libavcodec 57. 89.100 / 57. 89.100
libavformat 57. 71.100 / 57. 71.100
libavdevice 57. 6.100 / 57. 6.100
libavfilter 6. 82.100 / 6. 82.100
libavresample 3. 5. 0 / 3. 5. 0
libswscale 4. 6.100 / 4. 6.100
libswresample 2. 7.100 / 2. 7.100
libpostproc 54. 5.100 / 54. 5.100
Input #0, matroska,webm, from 'output2.mkv':
Metadata:
ENCODER : Lavf56.15.102
Duration: 00:00:46.17, start: 0.000000, bitrate: 152355 kb/s
Stream #0:0: Video: mjpeg, yuvj422p(pc, bt470bg/unknown/unknown), 1920x1080, SAR 1:1 DAR 16:9, 30 fps, 30 tbr, 1k tbn, 1k tbc (default)
At least one output file must be specified
As you can see, it’s mjpeg, in yuvj422p pixel format, bt407bg colourspace, 1920x1080, 30 fps.
I’m going to list 5 examples that involve nvjpegdec and nvvidconv:
Case 1: filesrc location=output2.mkv ! nvjpegdec ! ‘video/x-raw(memory:NVMM)’ ! nvhdmioverlaysink
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=output2.mkv ! nvjpegdec ! nvhdmioverlaysink -v
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingPipeline is PREROLLING ...
/GstPipeline:pipeline0/GstNvJpegDec:nvjpegdec0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:0:0, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstNvHDMIOverlaySink-nvhdmioverlaysink:nvhdmioverlaysink-nvhdmioverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:0:0, framerate=(fraction)0/1
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:04.133629995
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Note that nvhdmioverlaysink accepts video/x-raw(memory:NVMM), format=(string)I420 here.
Result: video displayed via HDMI overlay on LCD screen. However, chroma is incorrectly expanded in the vertical direction (doubled in height), while luma remains correct.
Case 2: filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=I420’ ! nvhdmioverlaysink
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvhdmioverlaysink -v
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)I420
/GstPipeline:pipeline0/GstNvHDMIOverlaySink-nvhdmioverlaysink:nvhdmioverlaysink-nvhdmioverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)I420
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:0:0, framerate=(fraction)0/1
Execution ended after 0:00:03.995583364
Note that both the src and sink pads of nvvidconv are negotiated as video/x-raw(memory:NVMM), format=(string)I420, so the conversion should a no-op.
Result: the overlay is completely green.
Case 3: filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=UYVY’ ! nvhdmioverlaysink
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! 'video/x-raw(memory:NVMM), format=UYVY' ! nvhdmioverlaysink -v
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
/GstPipeline:pipeline0/GstNvHDMIOverlaySink-nvhdmioverlaysink:nvhdmioverlaysink-nvhdmioverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
Execution ended after 0:00:10.847353605
Note that nvhdmioverlaysink claims to accept video/x-raw(memory:NVMM), format=(string)UYVY here.
Result: the overlay is completely black.
Case 4: filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=GRAY8’ ! nvhdmioverlaysink
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=output2.mkv ! nvjpegdec ! nvvidconv ! 'video/x-raw(memory:NVMM), format=GRAY8' ! nvhdmioverlaysink -v
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)GRAY8
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)GRAY8
/GstPipeline:pipeline0/GstNvHDMIOverlaySink-nvhdmioverlaysink:nvhdmioverlaysink-nvhdmioverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)GRAY8
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)GRAY8
Execution ended after 0:00:03.511661359
Note that between nvvidconv and nvhdmioverlaysink, the caps are negotiated as video/x-raw(memory:NVMM), format=(string)GRAY8, so I expect the resulting rendered video to be in grayscale.
Result: video rendered in correct colours, not in grayscale, via HDMI overlay on LCD screen (WHAT!?)
Case 5: filesrc location=output2.mkv ! nvjpegdec ! ‘video/x-raw(memory:NVMM)’ ! nvvidconv ! xvimagesink
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=output2.mkv ! nvjpegdec ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! xvimagesink -v
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:0:0, framerate=(fraction)0/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, framerate=(fraction)0/1, format=(string)UYVY
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)1:4:0:0, framerate=(fraction)0/1
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Output window was closed
Additional debug info:
xvimagesink.c(551): gst_xvimagesink_handle_xevents (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0
Execution ended after 0:00:08.186343916
Note that I now try to convert from I420 in NVMM to UYVY in regular RAM, so that I can display the video in standard sinks like xvimagesink.
Result: video rendered in a window in correct colours, but the whole image is slightly stretched vertically, with the bottom cropped.
