Can orin nx use the same camera model at the same time?
I connected two imx219 cameras to the orin nx developer kit. After configuring jetson io, I used the
nvgstcapture-1.0 --cap-dev-node=0
nvgstcapture-1.0 --cap-dev-node=1
command to output images in the terminal. I found that I could not display the images of two cameras at the same time. When one is displayed, the other will be black.
The phenomenon is:
  1. Connect the camera to CAM0 or CAM1, and each camera is available
  2. Connect the camera to CAM0 and CAM1 respectively, and input nvgstcapture-1.0 --cap-dev-node=1 to only output the image of CAM0
    Does orin nx support the simultaneous display of two images by default? I also have the same problem when using v4l2-ctl to obtain the stream.
    The system I use is jetpack5.1.2 flashed by sdk manager. If you have 2 cameras, can you help test it? Thank you very much.
Use --sensor-id=0/1 instead of --cap-dev-node for CSI camera.
Thank you very much, it solved my problem. By the way, does --cap-dev-node only support v4l2 cameras?
Use for USB camera.
If I want to get the image of the CSI camera, which document should I refer to for development.
Check below documents.
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Multimedia/AcceleratedGstreamer.html?#id15
https://docs.nvidia.com/jetson/l4t-multimedia/classArgus_1_1ISourceSettings.html#a50b962954ae6fcc9d024999390383071
