Hi,I noticed that sdkmanager method only support orin nano devkit with jetpack 6.2 which own a super mode,I want to make sure if anyway to support super mode on orin sku3 now?
The boost was done for AGX Orin since it’s launched.
Release note of jetpack6.2 metioned about the super performance of orin nx,but all the way to make super configuraiton only match with orin nano develop kit,I’m just so confused.
Could you share the results with below commands?
cat /etc/nvpmodel.conf
and
sudo nvpmodel -q
If I use sdkmanager to install jetpack6.2 on orin module without sdcard slot,for example orin nx 8GB,power only can be set as 10W/15W/20W,which means it cannot reach super performance.
And now I found a new way,install Jetson Linux 36.4 at first and install jetpack later,it seems that works.Maybe you should provide an official guide of the module without sdcard slot,I just found everytime I can only solve the problem by myself.
