I cant get my Jetson Orin Nano 8gb dev kit showing MAXN in power mode options. I got only options:
0: 15W
1: 7W
I bought the board in november (just before Jetson Orin Nano Super release). I follow the instructions in Jetson Orin Nano Developer Kit Getting Started Guide | NVIDIA Developer to update the firmware and tried to run sudo rm -rf /etc/nvpmodel.conf and restart without luck.
I tried to run following commands, but nothing changes after restart.
sudo ln -s /etc/nvpmodel/nvpmodel_p3767_0003_super.conf /etc/nvpmodel.conf
These are the files I got into the folder /etc/nvpmodels:
At the moment I got the following software versions running: L4T_VERSION=36.4.3 JETPACK_VERSION=6.2 CUDA_VERSION=12.6. Everything is working fine except for the power mode limited at 15W.
Can I have some directions to solve this issue?
kayccc
January 28, 2025, 4:57am
2
I dont have a ubuntu host to use SDK manager. In my Windows machine, I followed the instructions provided in Jetson Orin Nano Developer Kit Getting Started Guide | NVIDIA Developer . It is possible to get MAXN available using this method, or use SDK manager in a Windows machine?
DaneLLL
February 3, 2025, 12:37am
5
Please check if your Orin Nano module has SD card slot. If yes, please try the steps to update it:
🚀 Initial Setup Guide - Jetson Orin Nano - NVIDIA Jetson AI Lab
If it still fails, we would suggest have an Ubuntu host PC. For enabling super mode, the system has to be re-flashed.
my jetson orin nano 8gb dev kit does not have SD Card reader.
When will the SDK manager version for dev kit cards without SD reader be released?
DaneLLL
February 3, 2025, 12:49pm
7
Jetpack 6.2 supports the module. Super mode should be enabled if you use SDKManager to flash the developer kit.
Please try to download/extract BSP and sample rootfs on the host PC:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
The packages are in
Jetson Linux | NVIDIA Developer
Driver Package (BSP)
Sample Root Filesystem
And run the command to flash the developer kit:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit-super internal
system
Closed
February 26, 2025, 2:38am
9
