How to set MAXN Power Mode on Jetson Orin Nano Super booting from an SSD
I have installed the OS onto an SSD following parts of both these tutorials:
I know both of these are for other devices but they work for the Jetson Orin Nano Super.
Running jtop confirms that it is aware that it is the p3767-0005 NVIDIA Jetson Orin Nano Developer Kit
I am accessing the device headless over ssh, so I can’t see BIOS options or change the power mode through the desktop. I tried to set the Power Mode to MAXN, but nvpmodel -m 2 responds with NVPM ERROR: request for bad power mode 2.
When I checked /etc/nvpmodel.conf, it didn’t show the MAXN power mode. I have attached my current nvpmode.conf (as nvpmode.conf.txt) to this post. I’ve also deleted the file and rebooted, but the option doesn’t show up.
nvpmodel.conf.txt (4.8 KB)
I also read in a few places that you need to install it via the SDK Manager, but I don’t want to reinstall the Jetson Orin Nano from scratch.
I found what the nvpmode.conf should have on this page and I can manually add a power mode but I don’t know if that is the best solution.
After looking at this forum post, the response from nvpmodel -q --verbose is
nvpmodelverboselogs.txt (2.2 KB)
What should I do next? I appreciate any suggestions.
What is the exact BSP version you are running on your board?
Only the latest Jetapck version from sdkmanager will enable Orin Nano super mode.
Hi! Thanks for the quick response.
I’m not sure where I can find my BSP version, but I am running Jetpack 5.1.2, L4T 35.4.1, and it’s release 5.10.120-tegra.
I did just realize that Jetpack 5.1.2 isn’t the latest version, so I will flash the Jetson again with SDK Manager and get back to you.
Only latest jetpack6 one will have it. Even the latest jetpack5 one won’t have.
Thank you! That did indeed fix it.
