Can the Speed of nvvideoconvert Vary?
  1. Hardware Platform (Jetson / GPU)
  • RTX3090ti
  1. DeepStream Version
  • 7.0
$ docker run --gpus all \
    --privileged \
    --env="DISPLAY" \
    -it \
    -v /hdd/data:/Dataset \
    -v /tmp/.X11-unix:/tmp/.X11-unix \
    --name ds7 \
    --shm-size=32G nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
  1. NVIDIA GPU Driver Version (valid for GPU only)
  • 550.90.07
I have a DeepStream pipeline written in Python.
Each appsrc retrieves frames from a mp4 video (h.264)
(cv2.VideoCapture is used in the backend, so that I can easily switch to my USB camera if needed. NOT DURING RUNTIME)
I have found that Nvinfer performs about 180fps.
When I run the same pipeline format using deepstream-app (cli), Nvinfer performs at 330fps (with the same model and input videos).
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=2
[source0]
enable=1
type=3
uri=file:///root/Developments/backup/20240725/2024-07-25-07-41-52/raw/output_0.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
uri=file:///root/Developments/backup/20240725/2024-07-25-07-41-52/raw/output_1.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=0
type=2
sync=0
gpu-id=0
nvbuf-memory-type=2
[osd]
enable=0
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=2
[streammux]
gpu-id=0
live-source=0
batch-size=8
batched-push-timeout=40000
width=800
height=600
enable-padding=0
nvbuf-memory-type=2
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=2
config-file=config_infer_primary_yoloV5.txt
[tests]
file-loop=1
I decided to go through each element in the pipeline. When I attached a probe to nvvidconvert that comes after appsrc
Do you notice the pattern?
nvvideoconvert latency: 0.019312 seconds
nvvideoconvert latency: 0.000924 seconds
nvvideoconvert latency: 0.000317 seconds
nvvideoconvert latency: 0.000324 seconds
nvvideoconvert latency: 0.017491 seconds
nvvideoconvert latency: 0.001043 seconds
nvvideoconvert latency: 0.000747 seconds
nvvideoconvert latency: 0.000354 seconds
nvvideoconvert latency: 0.017785 seconds
nvvideoconvert latency: 0.000679 seconds
nvvideoconvert latency: 0.000447 seconds
nvvideoconvert latency: 0.000508 seconds
nvvideoconvert latency: 0.018169 seconds
nvvideoconvert latency: 0.000715 seconds
nvvideoconvert latency: 0.000429 seconds
nvvideoconvert latency: 0.000518 seconds
nvvideoconvert latency: 0.021060 seconds
nvvideoconvert latency: 0.000573 seconds
nvvideoconvert latency: 0.000606 seconds
nvvideoconvert latency: 0.000339 seconds
nvvideoconvert latency: 0.032315 seconds
nvvideoconvert latency: 0.000598 seconds
nvvideoconvert latency: 0.000335 seconds
nvvideoconvert latency: 0.000719 seconds
nvvideoconvert latency: 0.021168 seconds
nvvideoconvert latency: 0.000541 seconds
nvvideoconvert latency: 0.000328 seconds
nvvideoconvert latency: 0.000337 seconds
nvvideoconvert latency: 0.018323 seconds
nvvideoconvert latency: 0.000516 seconds
nvvideoconvert latency: 0.000531 seconds
nvvideoconvert latency: 0.000303 seconds
nvvideoconvert latency: 0.018292 seconds
nvvideoconvert latency: 0.000522 seconds
nvvideoconvert latency: 0.000947 seconds
nvvideoconvert latency: 0.000486 seconds
nvvideoconvert latency: 0.017310 seconds
nvvideoconvert latency: 0.000653 seconds
nvvideoconvert latency: 0.001019 seconds
nvvideoconvert latency: 0.000389 seconds
nvvideoconvert latency: 0.019968 seconds
nvvideoconvert latency: 0.000596 seconds
nvvideoconvert latency: 0.000611 seconds
nvvideoconvert latency: 0.000299 seconds
nvvideoconvert latency: 0.019073 seconds
nvvideoconvert latency: 0.000603 seconds
nvvideoconvert latency: 0.000364 seconds
nvvideoconvert latency: 0.018484 seconds
nvvideoconvert latency: 0.001057 seconds
nvvideoconvert latency: 0.000462 seconds
nvvideoconvert latency: 0.000476 seconds
nvvideoconvert latency: 0.022121 seconds
nvvideoconvert latency: 0.000668 seconds
nvvideoconvert latency: 0.000340 seconds
nvvideoconvert latency: 0.000401 seconds
nvvideoconvert latency: 0.019927 seconds
nvvideoconvert latency: 0.000620 seconds
nvvideoconvert latency: 0.000579 seconds
nvvideoconvert latency: 0.000470 seconds
nvvideoconvert latency: 0.018317 seconds
nvvideoconvert latency: 0.000877 seconds
nvvideoconvert latency: 0.018869 seconds
nvvideoconvert latency: 0.000604 seconds
nvvideoconvert latency: 0.000379 seconds
nvvideoconvert latency: 0.000306 seconds
nvvideoconvert latency: 0.019991 seconds
nvvideoconvert latency: 0.000798 seconds
nvvideoconvert latency: 0.000587 seconds
So my question is,
Is it possible that nvvideoconvert suddenly becomes slow and returns under any circumstances?
This is my pipeline in Python.
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append(
    "/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps"
import os
import gi
import cv2
import argparse
gi.require_version("Gst", "1.0")
from gi.repository import GLib, Gst
from common.platform_info import PlatformInfo
from common.bus_call import bus_call
from common.FPS import PERF_DATA
from termcolor import cprint
from pathlib import Path
import configparser
import pandas as pd
import datetime
import pyds
import glob
import numpy as np
from camera import CAMERA
from analysis import Analysis
from utils import buffer_probe, get_env_bool
from video_utils import VideoLoader
from dotenv import load_dotenv
load_dotenv(override=True)
LEFT_VIDEO_PATH = os.getenv('LEFT_VIDEO_PATH')
RIGHT_VIDEO_PATH = os.getenv('RIGHT_VIDEO_PATH')
print(LEFT_VIDEO_PATH)
print(RIGHT_VIDEO_PATH)
current_date = datetime.datetime.now().strftime("%Y-%m-%d-%H-%M-%S")
perf_data = None
MUXER_BATCH_TIMEOUT_USEC = 40000
WIDTH = 800
HEIGHT = 600
FPS = 500
BATCH_SIZE = 8
QUEUE_MAX_SIZE_BUFFER = 4294967295
QUEUE_MAX_SIZE_BYTES = 10485760
QUEUE_MAX_SIZE_TIME = 1000000000
IS_REALTIME = get_env_bool("IS_REALTIME")
IS_TRACKER_ENABLED = get_env_bool("IS_TRACKER_ENABLED")
IS_RECORDING = get_env_bool("IS_RECORDING")
IS_LOOPING = get_env_bool("IS_LOOPING")
IS_RECORDING_INPUT = get_env_bool("IS_RECORDING_INPUT")
images = glob.glob("images/*.jpg")
dummy_frames = [cv2.imread(img) for img in images]
dummy_frames = [cv2.resize(frame, (800, 600)) for frame in dummy_frames]
# Dictionary to store timestamps for buffers entering nvvideoconvert
timestamps = {}
def sink_pad_probe_nvvideoconvert(pad, info, u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return Gst.PadProbeReturn.OK
    # Get the buffer PTS (Presentation Timestamp)
    buffer_pts = gst_buffer.pts
    # Store the timestamp with the buffer PTS as the key
    timestamps[buffer_pts] = time.time()
def src_pad_probe_nvvideoconvert(pad, info, u_data):
    if not gst_buffer:
    # Calculate the latency
    entry_time = timestamps.pop(buffer_pts, None)
    if entry_time is not None:
        exit_time = time.time()
        latency = exit_time - entry_time
        print(f"nvvideoconvert latency: {latency:.6f} seconds")
# Define the callback for keyboard input
def on_keyboard_input(fd, condition, pipeline):
    if condition == GLib.IOCondition.IN:
        input_char = os.read(fd, 1).decode('utf-8')
        print(f"Input received: {input_char}")
        if input_char == 'q':
            print("Keyboard interrupt received, quitting...")
            pipeline.send_event(Gst.Event.new_eos())
            return False  # Remove the event source
    return True
def osd_sink_pad_buffer_probe(pad, info, nvinfer):
    frame_number = 0
    num_rects = 0
    is_ball_detected=False
    ball_detected_timer = 0
    if not gst_buffer:
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        num_rects = frame_meta.num_obj_meta
        raw_detection_data = []
        l_obj = frame_meta.obj_meta_list
        source_id = frame_meta.source_id
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            uniqueId = obj_meta.object_id
            classId = obj_meta.class_id
            objLabel = obj_meta.obj_label
            tBbox = obj_meta.detector_bbox_info.org_bbox_coords
            confidence = obj_meta.confidence
            left = tBbox.left
            width = tBbox.width
            top = tBbox.top
            height = tBbox.height
            center_x = left + width / 2
            center_y = top + height / 2
            raw_detection_data.append(
                    uniqueId,
                    classId,
                    objLabel,
                    left,
                    width,
                    top,
                    height,
                    confidence,
            # obj_counter[obj_meta.class_id] += 1
            obj_meta.rect_params.border_color.set(
                0.0, 0.0, 1.0, 0.8
            )  # 0.8 is alpha (opacity)
            try:
                l_obj = l_obj.next
                break
        # Acquiring a display meta object. The memory ownership remains in
        # the C code so downstream plugins can still access it. Otherwise
        # the garbage collector will claim it when this probe function exits.
        display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        # Setting display text to be shown on screen
        # Note that the pyds module allocates a buffer for the string, and the
        # memory will not be claimed by the garbage collector.
        # Reading the display_text field here will return the C address of the
        # allocated string. Use pyds.get_string() to get the string content.
        py_nvosd_text_params.display_text = (
            "Frame Number={} Number of Objects={}".format(
                frame_number,
                num_rects,
        # Now set the offsets where the string should appear
        py_nvosd_text_params.x_offset = 10
        py_nvosd_text_params.y_offset = 12
        # Font , font-color and font-size
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        # set(red, green, blue, alpha); set to White
        py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
        # Text background color
        py_nvosd_text_params.set_bg_clr = 1
        # set(red, green, blue, alpha); set to Black
        py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
        # Using pyds.get_string() to get display_text as string
        # print(pyds.get_string(py_nvosd_text_params.display_text))
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        # Update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        df = pd.DataFrame(
            raw_detection_data,
            columns=[
                "uniqueId",
                "classId",
                "objLabel",
                "left",
                "width",
                "top",
                "height",
                "confidence",
        filepath = f"./backup/{current_date}/detection/{source_id}_{frame_number}.csv"
        df.to_csv(filepath, index=False)
        try:
            l_frame = l_frame.next
            break
# Initialize the Analysis class
analysis = Analysis(None, None, None, None, None, None)
def tracker_src_pad_buffer_probe(pad, info, u_data):
    if not gst_buffer:
        return
    num_frames_in_batch = batch_meta.num_frames_in_batch
    # print("==============================")
    # print("num_frames_in_batch=",num_frames_in_batch)
        try:
            # it alone.
            break
        pad_index = frame_meta.pad_index
        # print("frame_number=",frame_number)
        # print("num_rects=",num_rects)
        # print("source_id=",source_id)
        # print("pad_index=",pad_index)
        raw_tracking_data = []
            try:
                break
            tBbox = obj_meta.tracker_bbox_info.org_bbox_coords
            tracker_confidence = (
                obj_meta.tracker_confidence
            )  # This is assuming you want to use the tracker confidence
            left = tBbox.left
            width = tBbox.width
            top = tBbox.top
            raw_tracking_data.append(
                    uniqueId,
                    classId,
                    objLabel,
                    left,
                    width,
                    top,
                    height,
                    confidence,
                    tracker_confidence,
            analysis.add_to_trajectory(source_id, uniqueId, frame_number, center_x, center_y)
            try:
                l_obj = l_obj.next
                break
        df = pd.DataFrame(
            raw_tracking_data,
            columns=[
                "uniqueId",
                "classId",
                "objLabel",
                "left",
                "width",
                "top",
                "height",
                "confidence",
                "age",
        # print(df)
        filepath = f"./backup/{current_date}/tracking/{source_id}_{frame_number}.csv"
        try:
            break
def on_demux_pad_added(demuxer, pad, bin, streammux, idx):
    demuxer = bin["demuxer"]
    capsfilter = bin["filter"]
    videoconvert = bin["video-converter"]
    queue = bin["queue"]
    caps = pad.get_current_caps()
    name = caps.to_string()
    if name.startswith("video/x-raw"):
        if demuxer.link(queue):
            cprint("demuxer -> queue link successful", "green")
        if queue.link(capsfilter):
            cprint("queue -> capsfilter link successful", "green")
        if capsfilter.link(videoconvert):
            cprint("capsfilter -> videoconvert link successful", "green")
        srcpad_videoconvert = videoconvert.get_static_pad("src")
        sinkpad_streammux = streammux.request_pad_simple(f"sink_{idx}")
        if srcpad_videoconvert.link(sinkpad_streammux) == Gst.PadLinkReturn.OK:
            cprint("videoconvert -> streammux link successful", "green")
        else:
            cprint("Failed to link videoconvert -> streammux", "red")
    else:
        cprint("Unknown format %s" % name, "red")
dummy_frames = [cv2.resize(frame, (WIDTH, HEIGHT)) for frame in dummy_frames]
import time
records = []
def cb_need_data(appsource, _pad, video_loader, video_idx):
    if type(video_loader) == CAMERA:
        start = time.time()
        frame = video_loader.capture_frames()
        end = time.time()
        if video_idx == 0:
            latency = end - start
            records.append([start, end, latency])
    else:
        frame = video_loader.get_next_frame()
    if frame is None:
        appsource.emit("end-of-stream")
    else:
        appsource.emit("push-buffer", Gst.Buffer.new_wrapped(frame.tobytes()))
def main(args):
    tracking_dir = Path(f"./backup/{current_date}/tracking/")
    tracking_dir.mkdir(parents=True, exist_ok=True)
    detection_dir = Path(f"./backup/{current_date}/detection/")
    detection_dir.mkdir(parents=True, exist_ok=True)
    video_dir = Path(f"./backup/{current_date}/videos/")
    video_dir.mkdir(parents=True, exist_ok=True)
    raw_dir = Path(f"./backup/{current_date}/raw/")
    raw_dir.mkdir(parents=True, exist_ok=True)
    config_path = args.config
    # Standard GStreamer initialization
    Gst.init(None)
    global perf_data
    perf_data = PERF_DATA(2)
    # Create gstreamer elements
    cprint("Creating Pipeline ...", "yellow")
    pipeline = Gst.Pipeline()
    if not pipeline:
        cprint("Unable to create Pipeline", "red")
        Cameras
    cam1 = {
        "source": Gst.ElementFactory.make("appsrc", "cam1"),
        "queue": Gst.ElementFactory.make("queue", "cam1_queue"),
        "filter": Gst.ElementFactory.make("capsfilter", "cam1_filter"),
        "video-converter": Gst.ElementFactory.make("nvvideoconvert", "cam1_vidconv"),
        "tee": Gst.ElementFactory.make("tee", "cam1_tee"),
    cam2 = {
        "source": Gst.ElementFactory.make("appsrc", "cam2"),
        "queue": Gst.ElementFactory.make("queue", "cam2_queue"),
        "filter": Gst.ElementFactory.make("capsfilter", "cam2_filter"),
        "video-converter": Gst.ElementFactory.make("nvvideoconvert", "cam2_vidconv"),
        "tee": Gst.ElementFactory.make("tee", "cam2_tee"),
    cam1_record = {
        "encoder": Gst.ElementFactory.make("nvv4l2h264enc", "cam1_encoder"),
        "parser": Gst.ElementFactory.make("h264parse", "cam1_parser"),
        "muxer": Gst.ElementFactory.make("qtmux", "cam1_muxer"),
        "sink": Gst.ElementFactory.make("filesink", "cam1_sink"),
    cam2_record = {
        "encoder": Gst.ElementFactory.make("nvv4l2h264enc", "cam2_encoder"),
        "parser": Gst.ElementFactory.make("h264parse", "cam2_parser"),
        "muxer": Gst.ElementFactory.make("qtmux", "cam2_muxer"),
        "sink": Gst.ElementFactory.make("filesink", "cam2_sink"),
    if not (cam2["source"] and cam2["video-converter"] and cam2["filter"] and cam2["queue"]):
        cprint("Unable to create Source", "red")
    if not (cam1["source"] and cam1["video-converter"]and cam1["filter"] and cam1["queue"]):
    cprint("Adding elements to Pipeline ...", "yellow")
    for cam_id, cam in enumerate([cam1, cam2]):
        if not pipeline.add(cam["source"]):
            cprint("Failed to add source to pipeline", "red")
        else:
            caps = Gst.Caps.from_string("video/x-raw, format=(string)BGR, width=(int)%d, height=(int)%d, framerate=(fraction)%d/1" % (WIDTH, HEIGHT, FPS))
            print(caps.to_string())
            cam["source"].set_property("caps", caps)
            # cam["source"].set_property('is-live', True)
            # cam["source"].set_property('block', True)
            # cam["source"].set_property('max-bytes', 200000)
            # cam["source"].set_property('do-timestamp', True)
            # cam["source"].set_property("format", Gst.Format.TIME)
        if not pipeline.add(cam["queue"]):
            cprint("Failed to add queue to pipeline", "red")
        else:
            cam["queue"].set_property("max-size-buffers", QUEUE_MAX_SIZE_BUFFER)
            cam["queue"].set_property("max-size-bytes", QUEUE_MAX_SIZE_BYTES)
            cam["queue"].set_property("max-size-time", QUEUE_MAX_SIZE_TIME)
        if not pipeline.add(cam["video-converter"]):
            cprint("Failed to add video-converter to pipeline", "red")
        # else:
            # if cam_id == 0:
            #     nvvidconv = cam["video-converter"]
            #     # Attach probes to the sink and src pads of nvvideoconvert
            #     nvvidconv_sink_pad = nvvidconv.get_static_pad("sink")
            #     if not nvvidconv_sink_pad:
            #         cprint("Unable to get sink pad of nvvideoconvert", "red")
            #     else:
            #         nvvidconv_sink_pad.add_probe(Gst.PadProbeType.BUFFER, sink_pad_probe_nvvideoconvert, 0)
            #     nvvidconv_src_pad = nvvidconv.get_static_pad("src")
            #     if not nvvidconv_src_pad:
            #         cprint("Unable to get src pad of nvvideoconvert", "red")
            #     else:
            #         nvvidconv_src_pad.add_probe(Gst.PadProbeType.BUFFER, src_pad_probe_nvvideoconvert, 0)
        if not pipeline.add(cam["filter"]):
            cprint("Failed to add capsfilter to pipeline", "red")
        else:
            caps = Gst.Caps.from_string("video/x-raw(memory:NVMM),format=NV12,width=%d,height=%d,framerate=%d/1" % (WIDTH, HEIGHT, FPS))
            cam["filter"].set_property("caps", caps)
        if not pipeline.add(cam["tee"]):
            cprint("Failed to add tee to pipeline", "red")
    if IS_RECORDING_INPUT:
        for i,cam in enumerate([cam1_record, cam2_record]):
            if not pipeline.add(cam["encoder"]):
                cprint("Failed to add encoder to pipeline", "red")
            else:
                cam["encoder"].set_property("bitrate", 800000000)
            if not pipeline.add(cam["parser"]):
                cprint("Failed to add parser to pipeline", "red")
            if not pipeline.add(cam["muxer"]):
                cprint("Failed to add muxer to pipeline", "red")
            if not pipeline.add(cam["sink"]):
                cprint("Failed to add sink to pipeline", "red")
            else:
                cam["sink"].set_property("location", f"{raw_dir}/output_{i}.mp4")
                cam["sink"].set_property("max-bitrate", 800000000)
                cam["sink"].set_property("sync", 0)
        Streammux & Caps
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "nvstreammux")
    if not streammux:
        cprint("Unable to create NvStreamMux", "red")
    streammux.set_property("width", WIDTH)
    streammux.set_property("height", HEIGHT)
    streammux.set_property("batch-size", BATCH_SIZE)
    streammux.set_property("nvbuf-memory-type", 2)
    streammux.set_property("batched-push-timeout", 10000)
    # streammux.set_property("buffer-pool-size", 16)
    # streammux.set_property("sync-inputs", True)
        Nvinfer
    # Use nvinfer to run inferencing on decoder's output,
    # behaviour of inferencing is set through config file
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        cprint(" Unable to create pgie", "red")
    pgie.set_property("config-file-path", config_path)
    pgie.set_property("batch-size", BATCH_SIZE)
        Nvtracker
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        cprint(" Unable to create tracker")
    # Set properties of tracker
    config = configparser.ConfigParser()
    config.read("./config_tracker.txt")
    config.sections()
    for key in config["tracker"]:
        if key == "tracker-width":
            tracker_width = config.getint("tracker", key)
            tracker.set_property("tracker-width", tracker_width)
        if key == "tracker-height":
            tracker_height = config.getint("tracker", key)
            tracker.set_property("tracker-height", tracker_height)
        if key == "gpu-id":
            tracker_gpu_id = config.getint("tracker", key)
            tracker.set_property("gpu_id", tracker_gpu_id)
        if key == "ll-lib-file":
            tracker_ll_lib_file = config.get("tracker", key)
            tracker.set_property("ll-lib-file", tracker_ll_lib_file)
        if key == "ll-config-file":
            tracker_ll_config_file = config.get("tracker", key)
            tracker.set_property("ll-config-file", tracker_ll_config_file)
        Nvtiler
    print("Creating nvdslogger ...")
    nvdslogger = Gst.ElementFactory.make("nvdslogger", "nvdslogger")
    if not nvdslogger:
        cprint(" Unable to create nvdslogger", "red")
    print("Creating tiler ...")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        cprint(" Unable to create tiler", "red")
    number_sources = 2
    tiler_rows = 2
    TILED_OUTPUT_WIDTH = WIDTH
    TILED_OUTPUT_HEIGHT = HEIGHT * 2
    tiler_columns = int(number_sources / tiler_rows)
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    print("Creating nvvidconv ...")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        cprint("Unable to create nvvidconv", "red")
    print("Creating nvosd ...")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        cprint("Unable to create nvosd", "red")
    # nvosd.set_property("display-text", 0)
    print("Creating EGLSink ...")
    # sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
    sink = Gst.ElementFactory.make("fakesink", "fakesink")
    if not sink:
        sys.stderr.write(" Unable to create egl sink")
    sink.set_property("qos", 0)
    sink.set_property("sync", 0)
    nvdsosd_tee = Gst.ElementFactory.make("tee", "nvdsosd_tee")
    if not nvdsosd_tee:
        cprint("Unable to create nvdsosd_tee", "red")
    queue_tee_0 = Gst.ElementFactory.make("queue", "queue_tee_0")
    queue_tee_1 = Gst.ElementFactory.make("queue", "queue_tee_1")
    if not queue_tee_0:
        cprint("Unable to create queue_tee_0", "red")
    if not queue_tee_1:
        cprint("Unable to create queue_tee_1", "red")
    queue_streammux_pgie = Gst.ElementFactory.make("queue", "queue1")
    qeueu_pgie_nvtracker = Gst.ElementFactory.make("queue", "queue2")
    queue_tracker_tiler = Gst.ElementFactory.make("queue", "queue3")
    for queue in [queue_streammux_pgie, qeueu_pgie_nvtracker, queue_tracker_tiler, queue_tee_0, queue_tee_1]:
        queue.set_property("max-size-buffers", QUEUE_MAX_SIZE_BUFFER)
        queue.set_property("max-size-bytes", QUEUE_MAX_SIZE_BYTES)
        queue.set_property("max-size-time", QUEUE_MAX_SIZE_TIME)
    pipeline.add(queue_streammux_pgie)
    pipeline.add(qeueu_pgie_nvtracker)
    pipeline.add(queue_tracker_tiler)
    pipeline.add(queue_tee_0)
    pipeline.add(queue_tee_1)
        Adding elements to pipeline
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(nvdslogger)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvdsosd_tee)
    pipeline.add(sink)
        Camera (1) - Queue & Tee
    # is_recording = False
    # source -> queue
    if not cam1["source"].link(cam1["queue"]):
        cprint("Failed to link source to queue", "red")
    if not cam2["source"].link(cam2["queue"]):
        cprint("Failed to link queue_main_cam2 to demuxer", "red")
    # queue -> video-converter
    if not cam1["queue"].link(cam1["video-converter"]):
        cprint("Failed to link queue to video-converter", "red")
    if not cam2["queue"].link(cam2["video-converter"]):
    # video-converter -> capsfilter
    if not cam1["video-converter"].link(cam1["filter"]):
        cprint("Failed to link video-converter to capsfilter", "red")
    if not cam2["video-converter"].link(cam2["filter"]):
    # capsfilter -> tee
    if not cam1["filter"].link(cam1["tee"]):
        cprint("Failed to link capsfilter to tee", "red")
    if not cam2["filter"].link(cam2["tee"]):
    # tee -> streammux
    cam1_tee_streammux = cam1["tee"].get_request_pad("src_%u")
    cam1_tee_file = cam1["tee"].get_request_pad("src_%u")
    if not (cam1_tee_streammux and cam1_tee_file):
        cprint("Unable to get the sink pad of streammux", "red")
    cam2_tee_streammux = cam2["tee"].get_request_pad("src_%u")
    cam2_tee_file = cam2["tee"].get_request_pad("src_%u")
    if not (cam2_tee_streammux and cam2_tee_file):
    sinkpad_streammux_cam1 = streammux.request_pad_simple("sink_0")
    if not sinkpad_streammux_cam1:
    sinkpad_streammux_cam2 = streammux.request_pad_simple("sink_1")
    if not sinkpad_streammux_cam2:
    if cam1_tee_streammux.link(sinkpad_streammux_cam1) != Gst.PadLinkReturn.OK:
        cprint("Failed to link source to streammux", "red")
    if cam2_tee_streammux.link(sinkpad_streammux_cam2) != Gst.PadLinkReturn.OK:
    if not streammux.link(queue_streammux_pgie):
        cprint("Failed to link streammux -> queue_streammux_pgie", "red")
        cam1_record_sink_pad = cam1_record["encoder"].get_static_pad("sink")
        cam2_record_sink_pad = cam2_record["encoder"].get_static_pad("sink")
        if not (cam1_record_sink_pad and cam2_record_sink_pad):
            cprint("Unable to get the sink pad of encoder", "red")
        if not cam1_tee_file.link(cam1_record_sink_pad):
            cprint("Failed to link tee to encoder", "red")
        if not cam1_record["encoder"].link(cam1_record["parser"]):
            cprint("Failed to link encoder to parser", "red")
        if not cam1_record["parser"].link(cam1_record["muxer"]):
            cprint("Failed to link parser to muxer", "red")
        if not cam1_record["muxer"].link(cam1_record["sink"]):
            cprint("Failed to link muxer to sink", "red")
        if not cam2_tee_file.link(cam2_record_sink_pad):
        if not cam2_record["encoder"].link(cam2_record["parser"]):
        if not cam2_record["parser"].link(cam2_record["muxer"]):
        if not cam2_record["muxer"].link(cam2_record["sink"]):
    """ Without videorate """
    if not queue_streammux_pgie.link(pgie):
        cprint("Failed to link queue_streammux_pgie -> pgie", "red")
    if not pgie.link(qeueu_pgie_nvtracker):
        cprint("Failed to link pgie -> nvtracker", "red")
    if IS_TRACKER_ENABLED:
        if not qeueu_pgie_nvtracker.link(tracker):
            cprint("Failed to link nvtracker -> tracker", "red")
        if not tracker.link(queue_tracker_tiler):
            cprint("Failed to link tracker -> tiler", "red")
    else:
        if not qeueu_pgie_nvtracker.link(queue_tracker_tiler):
    if not queue_tracker_tiler.link(tiler):
        cprint("Failed to link tiler -> nvvidconv", "red")
    if not tiler.link(nvvidconv):
        cprint("Failed to link nvvidconv -> nvosd", "red")
    if not nvvidconv.link(nvosd):
        cprint("Failed to link nvosd -> sink", "red")
    if not nvosd.link(nvdsosd_tee):
        cprint("Failed to link nvosd -> nvdsosd_tee", "red")
    if not nvdsosd_tee.link(queue_tee_0):
    if not queue_tee_0.link(sink):
        Save video
    if IS_RECORDING:
        h264enc = Gst.ElementFactory.make("nvv4l2h264enc", "h264enc")
        if not h264enc:
            cprint("Unable to create h264enc", "red")
        h264enc.set_property("bitrate", 800000000)
        caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=NV12, width={}, height={}, framerate={}/1".format(WIDTH, HEIGHT, FPS))
        filter = Gst.ElementFactory.make("capsfilter", "filter")
        filter.set_property("caps", caps)
        h264parse = Gst.ElementFactory.make("h264parse", "h264parse")
        if not h264parse:
            cprint("Unable to create h264parse", "red")
        qtmux = Gst.ElementFactory.make("qtmux", "qtmux2")
        if not qtmux:
            cprint("Unable to create qtmux", "red")
        filesink = Gst.ElementFactory.make("filesink", "filesink")
        if not filesink:
            cprint("Unable to create filesink", "red")
        filesink.set_property("location", f"{video_dir}/output.avi")
        filesink.set_property("max-bitrate", 800000000)
        filesink.set_property("sync", 0)
        pipeline.add(filter)
        pipeline.add(h264enc)
        pipeline.add(h264parse)
        pipeline.add(qtmux)
        pipeline.add(filesink)
        if not nvdsosd_tee.link(queue_tee_1):
            cprint("Failed to link nvdsosd_tee -> h264enc", "red")
        if not queue_tee_1.link(filter):
        if not filter.link(h264enc):
        if not h264enc.link(h264parse):
            cprint("Failed to link h264enc -> h264parse", "red")
        if not h264parse.link(qtmux):
            cprint("Failed to link h264parse -> qtmux", "red")
        if not qtmux.link(filesink):
            cprint("Failed to link qtmux -> filesink", "red")
    cprint("Linking complete!", "green")
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    # bus.connect("message::eos", on_eos, loop)
    # bus.connect("message::error", on_error, loop)
    # Add keyboard input listener
    # GLib.io_add_watch(sys.stdin, GLib.IOCondition.IN, on_keyboard_input, pipeline)
    GLib.io_add_watch(sys.stdin.fileno(), GLib.IOCondition.IN, on_keyboard_input, pipeline)
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        cprint("Unable to get sink pad of nvosd", "red")
    pgie_src_pad = pgie.get_static_pad("src")
    if not pgie_src_pad:
        cprint(" Unable to get src pad", "red")
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, pgie)
        # perf callback function to print fps every 5 sec
        GLib.timeout_add(5000, perf_data.perf_print_callback)
    tracker_src_pad = tracker.get_static_pad("src")
    if not tracker_src_pad:
    else:
        tracker_src_pad.add_probe(
            Gst.PadProbeType.BUFFER, tracker_src_pad_buffer_probe, 0
    # # Get the queue pads
    # queue_cam1_src_pad = cam1["queue"].get_static_pad("src")
    # queue_cam2_src_pad = cam2["queue"].get_static_pad("src")
    # queue_tee_0_sink_pad = queue_tee_0.get_static_pad("sink")
    # queue_tee_1_sink_pad = queue_tee_1.get_static_pad("sink")
    # queue_streammux_pgie_sink_pad = queue_streammux_pgie.get_static_pad("sink")
    # qeueu_pgie_nvtracker_sink_pad = qeueu_pgie_nvtracker.get_static_pad("sink")
    # queue_tracker_tiler_sink_pad = queue_tracker_tiler.get_static_pad("sink")
    # # Attach a probe to the queue pads
    # queue_cam1_src_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "cam1"
    # queue_cam2_src_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "cam2"
    # queue_tee_0_sink_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "queue_tee_0"
    # queue_tee_1_sink_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "queue_tee_1"
    # queue_streammux_pgie_sink_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "queue_streammux_pgie"
    # qeueu_pgie_nvtracker_sink_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "qeueu_pgie_nvtracker"
    # queue_tracker_tiler_sink_pad.add_probe(
    #     Gst.PadProbeType.BUFFER, buffer_probe, "queue_tracker_tiler"
       Video
    if IS_REALTIME:
        camera0 = CAMERA(0)
        camera1 = CAMERA(1)
        if not camera0.initialize():
            cprint("Failed to initialize camera 0", "red")
            sys.exit(1)
        if not camera1.initialize():
            cprint("Failed to initialize camera 1", "red")
            sys.exit(1)
        camera0.set_gamma(0.5)
        camera0.set_exposure_time(1700)
        camera0.set_white_balance(1.64,1.0, 1.4)
        camera0.set_fps_enable(FPS)
        camera1.set_gamma(0.5)
        camera1.set_exposure_time(1700)
        camera1.set_white_balance(1.64,1.0, 1.4)
        camera1.set_fps_enable(FPS)
        if not camera0.start_grabbing():
            cprint("Failed to start grabbing camera 0", "red")
            sys.exit(1)
        if not camera1.start_grabbing():
            cprint("Failed to start grabbing camera 1", "red")
            sys.exit(1)
        cam1["source"].connect("need-data", cb_need_data, camera0, 0)
        cam2["source"].connect("need-data", cb_need_data, camera1, 1)
    else:
        video_loader1 = VideoLoader(LEFT_VIDEO_PATH, 0, is_looping=IS_LOOPING)
        video_loader2 = VideoLoader(RIGHT_VIDEO_PATH, 0, is_looping=IS_LOOPING)
        cam1["source"].connect("need-data", cb_need_data, video_loader1, 0)
        cam2["source"].connect("need-data", cb_need_data, video_loader2, 1)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except Exception as e:
        pass
    if IS_REALTIME:
        camera0.stop_grabbing()
        camera1.stop_grabbing()
        camera0.close()
        camera1.close()
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
    pipeline.get_state(Gst.CLOCK_TIME_NONE)  # Wait until the state change is complete
    # analysis.show()
    # Save record as csv
    df = pd.DataFrame(records, columns=["start", "end", "frame"])
    df.to_csv(f"./records.csv", index=False)
if __name__ == "__main__":
    parser = argparse.ArgumentParser(description="DeepStream Test")
    parser.add_argument(
        "-i",
        "--input",
        type=str,
        default="../../../../samples/streams/sample_720p.h264",
        help="Path to the input video file",
        "-c",
        "--config",
        type=str,
        default="./models/yolov5/config_infer_primary_yoloV5_fp16_b10.txt",
        # default="./yolov4_last/config_infer_primary.txt",
        help="Path to the config file",
    args = parser.parse_args()
    main(args)
This post, Nvvideoconvert latency increase a lot after idle time, might be related, but we are not in Jetson platforms.
There is no such version
The latency data measured in this way only shows the GstBuffer staying time in this element. It may not equal to the nvvideoconvert processing time. E.G. If the downstream elements consume the GstBuffer late, the GstBuffer may stay in the current element for a longer time.
According to your pipeline graph and some of the code, your source are JPEG pictures which are decoded by software but not hardware, the decoding speed is not guaranteed.
There are three branches with "tee"s in your pipeline, the branches will impact each other. The slowest branches decide the final speed of the whole pipeline. I notice you do video encoding and file saving in some branches, it will be slower than fakesink. So it is not reasonable to compare the deepstream-app case with your pipeline.
