Use YUY2 format as input
I’m thinking of using v4l2src of YUY2 output with DeepStream of JetsonNano.
The image of pipeline is as below.
v4l2src(1920x1080, YUY2) ->capsfilter(for YUY2 input) → converter(format conversion)> nvstreammux > nvinfer(object detection) → nvtiler → nvvidconv → nvosd → nveglglessink
The pipeline works when use “videoconvert” element as the converter.
But fps on the display is very slow(about 5fps).
In result of my investigation, I found this caused due to do format conversion on CPU.
So I had thought use “nvvideoconvert”, but this element could not treat YUY2 format.
What shoud I do ?
We are checking to support UYVY and YUY2 in nvvideoconvert. As a temporary solution, you may try
https://devtalk.nvidia.com/default/topic/1063070/deepstream-sdk/nvvideoconvert-uyvy-support-on-xavier/post/5387008/#5387008
Thanks to your help, I was able to proceed.
The pipeline without nvinfer worked.
But inserting nvinfer didn’t worked.
What should I chaeck ?
(I had already checked config-file of nvinfer is loaded.)
<pipeline(worked)>
nvvidconv → capsfilter(convert format on GPU) →
nvvidconv → capsfilter(transfer to CPU) →
nvvideoconvert → capsfilter(transfer to GPU) →
nvstreammux →
nvmultistreamtiler rows=1 columns=1 width=1920 height=1080 →
nvvideoconvert → nvosd → nvegltransform → nvglglessink sync=false
<pipeline( NOT worked)>
nvvidconv) → capsfilter(transfer to CPU) →
nvstreammux → nvinfer config-file-path=dstest3_pgie_config.txt batch-size=1 →
Please check if you can apply your case to
deepstream_sdk_v4.0.1_jetson\sources\apps\sample_apps\deepstream-test1
There are many properties which must be configured in running a deepstream pipeline, it can be better to run a C-code application.
DaneLLL,
Thanks for your help.
I checked deepstream-test1, 3.
But my pipeline does not worked.
Is there anything I should be careful about when using “nvinfer”?
Please share your code based on deepstream-test1. We can check and suggest next.
our pipline is as below.
I inserted “queue” in several place, but it didn’t work.
v4l2src device=/dev/video0 ! "video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080" ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080" ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=dstest1_pgie_config.txt batch-size=1 ! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080 ! nvvideoconvert ! nvosd ! nvegltransform ! nvglglessink sync=false
Please zip yout deepstream_test1_app.c and attach it. We will replace it and rebuild/run deepstream-test1 to reproduce the failure.
OK, I’ll try make C source and post.
And I found that my pipeline works with “-v” option.
What’s the difference between with and without “-v”?
I’m sorry for the late reply.
I made C source based on deepstream-test3.
I compiled this, no error occured.
I’m sorry, but I found out that the source code cannot be disclosed due to the limitations of our environment.
But pipeline didn’t work.No video outputed but window was only created.
Please check the sample based on deepstream-test1:
 * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include "gstnvdsmeta.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
#define NVVIDCONV
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
  "Roadsign"
/* osd_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_number, num_rects, vehicle_count, person_count);
    frame_number++;
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL,
      *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL;
  GstElement *conv1 = NULL, *conv2 = NULL, *nvconv = NULL;
  GstCaps *caps_uyvy = NULL, *caps_nv12_nvmm = NULL, *caps_nv12 = NULL;
  GstCapsFeatures *feature = NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *osd_sink_pad = NULL;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("v4l2src", "v4l2-source");
#ifdef NVVIDCONV
  conv1 = gst_element_factory_make ("nvvidconv", "conv1");
  conv2 = gst_element_factory_make ("nvvidconv", "conv2");
#else
  conv1 = gst_element_factory_make ("videoconvert", "conv1");
#endif
  nvconv = gst_element_factory_make ("nvvideoconvert", "nvconv");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !pgie
      || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", 1, "live-source", 1,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest1_pgie_config.txt", NULL);
  g_object_set (G_OBJECT (source), "device", "/dev/video1", "num-buffers", 900, NULL);
  caps_uyvy = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "UYVY",
      "width", G_TYPE_INT, 1920, "height", G_TYPE_INT,
      1080, "framerate", GST_TYPE_FRACTION,
      30, 1, NULL);
  caps_nv12_nvmm = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  feature = gst_caps_features_new ("memory:NVMM", NULL);
  gst_caps_set_features (caps_nv12_nvmm, 0, feature);
  caps_nv12 = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),
      source, conv1, nvconv, streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL);
  gst_element_link_filtered(source, conv1, caps_uyvy);
#ifdef NVVIDCONV
  gst_bin_add (GST_BIN (pipeline), conv2);
  gst_element_link_filtered(conv1, conv2, caps_nv12_nvmm);
  gst_element_link_filtered(conv2, nvconv, caps_nv12);
#else
  gst_element_link_filtered(conv1, nvconv, caps_nv12);
#endif
  gst_element_link_pads_filtered(nvconv, "src", streammux, "sink_0", caps_nv12_nvmm);
  gst_caps_unref(caps_uyvy);
  gst_caps_unref(caps_nv12_nvmm);
  gst_caps_unref(caps_nv12);
  if (!gst_element_link_many (streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL)) {
    g_printerr ("Elements could not be linked: 2. Exiting.\n");
    return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
You can try either videoconvert plugin or two nvvidconv plugins by adding/removing:
#define NVVIDCONV
Thanks for your cooperation!
This is very helpful for me.
I’ll check the execution result and report it.
Your code worked in my environment!
I had changed some properties(numbuffer-> none, UYVY->YUY2 and so on).
Thank you !!
Dear DaneLLL,
I used the YUY2 camera to run the following pipeline on RTX2080 and it worked.
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=640 height=480 ! nvinfer config-file-path=dstest1_pgie_config.txt batch-size=1 unique-id=1 ! nvvideoconvert ! nvdsosd ! nveglglessink
However I modified your code from #11 to run the above pipeline. (I removed “define NVVIDCONV”, “num-buffer” , and changed WIDTH to 640, HEIGHT to 480, UYVY to YUY2, and so on. It passed build.) It always failed at the following error. Can you guide me how to troubleshoot it?
Creating LL OSD context new
0:00:01.186371153 19069 0x5579e9ad5700 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:10.034511640 19069 0x5579e9ad5700 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/mlgpu02/deepstream_sdk_v4.0.2_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
Running…
ERROR from element v4l2-source: Internal data stream error.
Error details: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:dstest1-pipeline/GstV4l2Src:v4l2-source:
streaming stopped, reason not-linked (-1)
Deleting pipeline
Thank you for your help.
Please share ‘# v4l2-ctl -d /dev/video0 --list-formats-ext’ for information.
Hello DaneLLL,
It is logitech C270 HD Webcam. The following is the information for ‘# v4l2-ctl -d /dev/video0 --list-formats-ext’ from my system.
Thank you.
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'YUYV'
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.040s (25.000 fps)
                        Interval: Discrete 0.050s (20.000 fps)
                        Interval: Discrete 0.067s (15.000 fps)
                        Interval: Discrete 0.100s (10.000 fps)
                        Interval: Discrete 0.200s (5.000 fps)
                        Interval: Discrete 0.133s (7.500 fps)
        Index       : 1
        Pixel Format: 'MJPG' (compressed)
        Index       : 2
        Pixel Format: 'RGB3' (emulated)
        Index       : 3
        Pixel Format: 'BGR3' (emulated)
        Index       : 4
        Pixel Format: 'YU12' (emulated)
        Index       : 5
        Pixel Format: 'YV12' (emulated)
Your camera does not support 1920x1080. Please try 640x480. The resolution has to be modified:
      30, 1, NULL);
Hi DaneDLL,
I followed my pipeline to changed the MUXER_OUTPUT_WIDTH to 640, MUXER_OUTPUT_HEIGHT to 480, same as the width and height in caps_uyvy from your code in #11. It passed build but it still got the same error although my pipeline could work.
Thank you.
Hi DaneLLL,
I used your code from #11 as it is and compile it on gtx 1080.
The compilation failed with giving error as:
“deepstream_test1_app.c:249:25: error: ‘transform’ undeclared (first use in this function); did you mean ‘srandom’?”
Then i removed all the appearances of ‘transform’ from code and then successfully compiled it again.
However when im trying to run the code on logitech c270 camera, it is giving me error as:
ERROR from element stream-muxer: memory type configured and i/p buffer mismatch ip_surf 0 muxer 3
Error details: gstnvstreammux.c(409): gst_nvstreammux_chain (): /GstPipeline:dstest1-pipeline/GstNvStreamMux:stream-muxer
Deleting pipeline
The output of ‘# v4l2-ctl -d /dev/video0 --list-formats-ext’ is as follows:
	Index       : 0
I also made changes as you suggested in #17 and as discussed in #13. But still getting same error.
Need your help to solve this problem.
hi,
We have verified the sample on Jetson Nano/DS4.0.1 + E-Con See3CAM-CU135. It shall work if you correctly configure the v4l2 source to meet supported mode in width, height, format, framerate. Suggest you break down the pipeline with fakesink. You may modify C code to run
v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! videoconvert ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! fakesink
See if the source can be successfully converted to ‘video/x-raw(memory:NVMM),format=NV12’
