How to run deepstream-test3 with usb camera
I can run deepstream-test3 with IP Camera(e.g. ./deepstream-test3 rtsp://admin:1234@192.168.1.40:554/h264/ch1/main/av_stream).
But how to run deepstream-test3 with a usb camera, what kind of command line parameters should I input?
Can someone give me some advise? Thanks.
You may get information about your usb cameras:
https://devtalk.nvidia.com/default/topic/1057681/jetson-tx1/logitech-c930e-on-jetson-tx1-very-slow-and-choppy-video/post/5363417/#5363417
And then replace uridecodebin with ‘v4l2src ! videoconvert ! nvvideoconvert’. Similar code is in
deepstream_sdk_v4.0_jetson\sources\apps\apps-common\src\deepstream_source_bin.c
It runs
v4l2src ! videoconvert ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12'
In running deepstream-app, some settings are put in config file. For running deepstream-test*, you need to configure it:
v4l2src ! <b>video/x-raw,format=YUY2,width=848,height=480,framerate=30/1</b> ! videoconvert ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12'
If you would like to run MJPEG source, you may refer to
https://devtalk.nvidia.com/default/topic/1058754/deepstream-sdk/how-to-change-source-pixel-format-from-yuyv-to-mjpg/post/5369809/#5369809
Hi, DaneLLL
Thanks for reply!
I have read the two posts you provided, but I still have two problems.
  1. I have successfully running deepstream-app with usb camera by modify configuration files. If I want to run deepstream-test-app* with usb camera, does it mean I need modify deepstream_sdk_v4.0_jetson\sources\apps\apps-common\src\deepstream_source_bin.c to configure it or configure it by changing sources\apps\sample-apps\deepstream-test*\dstest*_pgie_config.txt?
  2. if I need modify the source code, I am not sure how to modify it, does it like this?
caps = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "YUY2",
      "width", G_TYPE_INT, 848, "height", G_TYPE_INT,
      480, "framerate", GST_TYPE_FRACTION,
      30/1, config->source_fps_d, NULL);
Desperately need your help.
Thanks,
Newman97
You should modify
deepstream_sdk_v4.0_jetson\sources\apps\sample_apps\deepstream-test3\deepstream_test3_app.c
deepstream_source_bin.c is for your reference.
Hi DaneLLL,
Thanks for your help, I create a function named “create_camera_source_bin” to replace “uridecodebin” as deepstream_source_bin.c does. But when I run it with command “./deepstream-test3-app v4l2src”(here the second parameter can be ignored), I encounter the following errors.
(deepstream-test3-app:15312): GStreamer-WARNING **: 20:06:48.863: Name 'src_cap_filter' is not unique in bin 'source-bin-00', not adding
Failed to link 'nvvidconv2, cap_filter'
Failed to create source bin. Exiting.
The error information shows link nvvidconv2 with cap_filter failed, but I have no idea about how to fix this problem, can you give me some advise?
Here is the code of “create_camera_source_bin” function I add to deepstream_test3_app.c.
static GstElement *
create_camera_source_bin (guint index, gchar * uri)
  GstElement *bin = NULL;
  GstCaps *caps = NULL;
  gboolean ret = FALSE;
  gchar bin_name[16] = { };
  g_snprintf (bin_name, 15, "source-bin-%02d", index);
  bin = gst_bin_new (bin_name);
  GstElement *src_elem = gst_element_factory_make ("v4l2src", "src_elem");
  if (!src_elem)
    g_printerr ("Could not create 'src_elem'\n");
    return NULL;
  GstElement *cap_filter = gst_element_factory_make ("capsfilter", "src_cap_filter");
  if (!cap_filter){
    g_printerr ("Could not create 'src_cap_filter'\n");
    return NULL;
  caps = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING, "YUY2",
		  "width", G_TYPE_INT, 848, "height", G_TYPE_INT, 480,
		  "framerate", GST_TYPE_FRACTION, 30, 1, NULL);
  GstElement *nvvidconv1, *nvvidconv2;
  GstCapsFeatures *feature = NULL;
  nvvidconv1 = gst_element_factory_make ("videoconvert", "nvvidconv1");
  if (!nvvidconv1){
    g_printerr ("Failed to create 'nvvidcovn1'\n");
    return NULL;
  feature = gst_caps_features_new ("memory:NVMM", NULL);
  gst_caps_set_features (caps, 0, feature);
  g_object_set (G_OBJECT (cap_filter), "caps", caps, NULL);
  nvvidconv2 = gst_element_factory_make ("nvvideoconvert", "nvvidconv2");
  if (!nvvidconv2){
    g_printerr ("Failed to create 'nvvidcovn2'\n");
    return NULL;
  g_object_set (G_OBJECT (nvvidconv2), "gpu-id", 0, NULL);
  gst_bin_add_many (GST_BIN (bin), src_elem, cap_filter, nvvidconv1, nvvidconv2, cap_filter, NULL);
  //NVGSTDS_LINK_ELEMENT (src_elem, nvvidconv1);
  //NVGSTDS_LINK_ELEMENT (nvvidconv1, nvvidconv2);
  //NVGSTDS_LINK_ELEMENT (nvvidconv2, cap_filter);
  if (!gst_element_link (src_elem,nvvidconv1)){
    g_printerr ("Failed to link 'src_elem, nvvidcovn1'\n");
    return NULL;
  if (!gst_element_link (nvvidconv1,nvvidconv2)){
    g_printerr ("Failed to link 'nvvidcovn1, nvvidcovn2'\n");
    return NULL;
  if (!gst_element_link (nvvidconv2, cap_filter)){
    g_printerr ("Failed to link 'nvvidcovn2, cap_filter'\n");
    return NULL;
  // NVGSTDS_BIN_ADD_GHOST_PAD (bin, cap_filter, "src");
  GstPad *gstpad = gst_element_get_static_pad (cap_filter, "src");
  gst_element_add_pad (bin, gst_ghost_pad_new ("src", gstpad));
  gst_object_unref(gstpad);
  gchar device[64];
  g_snprintf (device, sizeof (device), "/dev/video%d", 0);
  g_object_set (G_OBJECT (src_elem), "device", device, NULL);
  return bin;
And I replace line 325 in deepstream_test3_app.c
GstElement *source_bin = create_source_bin (i, argv[i + 1]);
with
GstElement *source_bin = create_camera_source_bin (i, argv[i + 1]);
Thanks,
Newman97
Do you run ‘v4l2-ctl’ command to get all modes? ‘848x480 YUYV 30fps’ is an example and you have to adapt it to your camera output.
Hi DaneLLL,
Yes I have run ‘v4l2-ctl’ command and hav tried different resolution and format config (my usb camera have ‘MJPG’ and ‘YUYV’ pixel format). Finally I solved the problem by replacing ‘YUY2’ format with ‘NV12’ format in line 25~27.
with
caps = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING, "NV12",
It works now, but the video is slow and I am trying to solve it with the two reference post.
Thanks for your help.
Best regards,
Newman97
You should create two cap_filter in the implementation. One is for v4l2src and the other is for nvvideoconvert.
For v4l2src, pick one supported mode:
For nvvideoconvert, it is
It looks like you only create one ‘video/x-raw(memory:NVMM),format=YUY2,width=848,height=480,framerate=30/1’. It should not work.
newman97
Could I get your code?
Hi DaneLLL,
I am trying to use USB camera on Jetson Nano. It runs smoothly with deepstream-app. I also tried using test-1 sample app with the code below but output is choppy. Could you please indicate what I am doing wrong?
Best regards.
static GstElement *
add_source_bin (void)
  GstElement *src_bin = NULL;
  gchar srcbin_name[16] = { };
  GstCaps *lnvcaps = NULL;
  src_bin = gst_bin_new (srcbin_name);
  GstElement *src_elem = gst_element_factory_make (NVDS_ELEM_SRC_CAMERA_V4L2, "src_elem");
  gchar device[64];
  GstElement *cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, "src_cap_filter");
  nvvidconv2 = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, "nvvidconv2");
  g_object_set (G_OBJECT (nvvidconv2), "gpu-id", 0, "nvbuf-memory-type", 0, NULL);
  caps = gst_caps_new_simple("video/x-raw","format", G_TYPE_STRING, "YUY2",
		  "width", G_TYPE_INT, 800, "height", G_TYPE_INT, 600,
		  "framerate", GST_TYPE_FRACTION, 30,1, NULL);
  lnvcaps = gst_caps_new_simple("video/x-raw", "format", G_TYPE_STRING,"NV12",
		  "width", G_TYPE_INT, 480, "height", G_TYPE_INT, 272,
  gst_caps_set_features (lnvcaps, 0, feature);
  g_object_set (G_OBJECT (cap_filter), "caps", lnvcaps, NULL);
  gst_bin_add_many (GST_BIN (src_bin), src_elem, nvvidconv1, nvvidconv2, cap_filter, NULL);
  if (!gst_element_link_filtered (src_elem, nvvidconv1, caps)){
    g_printerr ("Failed to link 'src_elem, nvvidconv1'\n");
    return NULL;
    g_printerr ("Failed to link 'nvvidconv1, nvvidconv2'\n");
    return NULL;
    g_printerr ("Failed to link 'nvvidconv2, cap_filter'\n");
    return NULL;
  gst_element_add_pad (src_bin, gst_ghost_pad_new ("src", gstpad));
  gst_caps_unref (caps);
  gst_caps_unref (lnvcaps);
  return src_bin;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL;
  GstElement *transform = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *osd_sink_pad = NULL;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  GstElement *source = add_source_bin();
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  g_object_set (G_OBJECT (nvvidconv), "gpu-id", 0, NULL);
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", 1,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest1_pgie_config.txt", NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),
      source, streammux, pgie, nvvidconv, nvosd, transform, sink, NULL);
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (source, pad_name_src);
  if (!srcpad) {
    g_printerr ("Source request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
      return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* we link the elements together */
  if (!gst_element_link_many (streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL)) {
    g_printerr ("Elements could not be linked: 2. Exiting.\n");
    return -1;
  /* Set the pipeline to "playing" state */
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
Please check this patch
Now it works smoothly.
Thanks a lot
Hi @DaneLLL,
I am having trouble applying that patch to this code. Things are different enough that I am lost.
Here is the function that works for me for two cameras, but it is slow as expected.
static GstElement *
  if (!src_elem)
    return NULL;
  gchar cap_filt_char[64];
  g_snprintf (cap_filt_char, sizeof (cap_filt_char), "src_cap_filter_%d", index);
  GstElement *cap_filter = gst_element_factory_make ("capsfilter", cap_filt_char);
  if (!cap_filter){
    return NULL;
		  "width", G_TYPE_INT, 1920, "height", G_TYPE_INT, 1080,
		  "framerate", GST_TYPE_FRACTION, 60, 1, NULL);
  if (!nvvidconv1){
    return NULL;
  if (!nvvidconv2){
    return NULL;
    return NULL;
    return NULL;
    return NULL;
  gchar device[64];
  g_snprintf (device, sizeof (device), "/dev/video%d", index);
  return bin;
How would I apply that patch to this example? I find all this gstreamer code to be pretty non-intuitive. My cameras are Econsystems USB3 cameras with UYVY output. I am using DS5.0 and the Jetson Nano.
Thank you!
And here is my attempt to merge in the patch. It does not work, throwing the error “streaming stopped, reason not-linked”.
static GstElement *
//  GstElement *nvvidconv1, *nvvidconv2;
  GstElement *conv1 = NULL, *conv2 = NULL, *nvconv = NULL;
  GstCaps *caps_uyvy = NULL, *caps_nv12_nvmm = NULL, *caps_nv12 = NULL;
  conv1 = gst_element_factory_make ("nvvidconv", "conv1");
  conv2 = gst_element_factory_make ("nvvidconv", "conv2");
  caps_uyvy = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "UYVY",
      1080, "framerate", GST_TYPE_FRACTION,
      60, 1, NULL);
  caps_nv12_nvmm = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  gst_caps_set_features (caps_nv12_nvmm, 0, feature);
  g_object_set (G_OBJECT (cap_filter), "caps", caps_nv12_nvmm, NULL);
  caps_nv12 = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  //nvvidconv2 = gst_element_factory_make ("nvvideoconvert", "nvvidconv2");
  nvconv = gst_element_factory_make ("nvvideoconvert", "nvconv");
  gchar device[64];
//  g_object_set (G_OBJECT (nvvidconv2), "gpu-id", 0, NULL);
  gst_bin_add_many (GST_BIN (bin), src_elem, cap_filter, conv1, nvconv, NULL);
  gst_element_link_filtered(src_elem, conv1, caps_uyvy);
  gst_bin_add (GST_BIN (bin), conv2);
  gst_element_link_filtered(conv1, conv2, caps_nv12_nvmm);
  gst_element_link_filtered(conv2, nvconv, caps_nv12);
  gst_element_link_filtered(nvconv, cap_filter, caps_nv12_nvmm);
  return bin;
This code is merged in to deepstream_test3_app.c from DS5.0. As mentioned above you must also replace line 325 in deepstream_test3_app.c
with
Any help is appreciated!
By default it is uridecodebin in deepstream-test3. You need to replace it with
v4l2src ! video/x-raw,format=_SOURCE_FORMAT_,width=_SOURCE_WIDTH_,height=SOURCE_HEIGHT_,framerate=_SOURCE_FRAMERATR_ ! videoconvert ! nvvideoconvert ! video/x-raw(memory:NVMM),format=NV12
You can refer to this post to set precise format,width,height,framerate.
Thank you, but I don’t understand how to convert these pipeline commands in to C++ code. I wasn’t able to understand it from reading the code. I suppose I will have to find a tutorial that explains it. Do you know of such a tutorial?
I did succeed in getting fast video processing with one camera using the recommended modifications to deepstream-test-1, I just do not get how to update deepstream-test-3 to do the same with multiple cameras.
Is there anyway to skip videoconvert plugin?
We will have enhancement in next release. Please wait for DS 5.0 GA.
How can i do this in deepstream 5
deepstream-test5 and deepstream-app are with common code in source group. You can configure it in config file. Please look at
DeepStream Reference Application - deepstream-app — DeepStream DeepStream Version: 5.0 documentation
