Hi @Fiona.Chen , @kayccc ,
I modified the python DS test3 script for multiple USB cameras. I have attached the source bin script below. I am getting a very low FPS (<10). Please help me to achieve a higher FPS.
Device : Jetson nano - Jetpack 4.4
**• DeepStream Version 5.01
**• TensorRT Version 7.1.3
def create_source_bin(index,uri):
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name="source-bin-%02d" %index
print(bin_name)
nbin=Gst.Bin.new(bin_name)`Preformatted text`
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
usb_cam_source=Gst.ElementFactory.make("v4l2src", "source")
usb_cam_source.set_property("device",uri)
caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps")
if not caps_v4l2src:
sys.stderr.write(" Unable to create v4l2src capsfilter \n")
# videoconvert to make sure a superset of raw formats are supported
vidconvsrc = Gst.ElementFactory.make("videoconvert", "convertor_src1")
if not vidconvsrc:
sys.stderr.write(" Unable to create videoconvert \n")
nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "convertor_src2")
if not nvvidconvsrc:
sys.stderr.write(" Unable to create Nvvideoconvert \n")
caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
if not caps_vidconvsrc:
sys.stderr.write(" Unable to create capsfilter \n")
caps_v4l2src.set_property('caps', Gst.Caps.from_string("video/x-raw, framerate=30/1"))
caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM), format=NV12"))
print('adding element to source bin')
Gst.Bin.add(nbin,usb_cam_source)
#Gst.Bin.add(nbin,jpegDec)
Gst.Bin.add(nbin,caps_v4l2src)
Gst.Bin.add(nbin,vidconvsrc)
Gst.Bin.add(nbin,nvvidconvsrc)
Gst.Bin.add(nbin,caps_vidconvsrc)
print('linking elemnent in source bin')
usb_cam_source.link(caps_v4l2src)
caps_v4l2src.link(vidconvsrc)
vidconvsrc.link(nvvidconvsrc)
nvvidconvsrc.link(caps_vidconvsrc)
pad = caps_vidconvsrc.get_static_pad("src")
ghostpad = Gst.GhostPad.new("src",pad)
bin_pad=nbin.add_pad(ghostpad)
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
My camera specifications are given below,
logitech c270 camera
(base) ajithbalakrishnan@AB:~$ v4l2-ctl -d /dev/video2 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index : 1
Pixel Format: 'MJPG' (compressed)
Index : 2
Pixel Format: 'RGB3' (emulated)
Index : 3
Pixel Format: 'BGR3' (emulated)
Index : 4
Pixel Format: 'YU12' (emulated)
Index : 5
Pixel Format: 'YV12' (emulated)
