Can we fix the number of GPU Cores used during a TensorRT inference execution? & is (Multi-instance GPU) MIG Available on Jetson AGX Thor
Can we fix the number of GPU Cores used during a TensorRT inference execution? I am running an inference code on Jetson AGX thor, can i control the number of GPU cores used during the particular execution?
Also is (Multi-instance GPU) MIG Available on Jetson AGX Thor Developer Kit.?
MIG support for Thor is added in Jetpack 7.2.
Please find the corresponding document below:
I have set up two Multi-Instance GPU (MIG) instances on a Jetson AGX Thor system.
  1. Is there a specific command or tool to monitor the exact memory used by each MIG instance on Jetson Thor? I have looked into tegrastats, but it seems to aggregate overall system/GPU usage.
  2. When examining the available MIG profiles, the profile layouts (such as profile 78 and 83) allocate 12 SMs and 6 SMs respectively. Combined, this accounts for 18 SMs.
    What happens to the remaining 2 SMs?
Hello @neethujoseph02,
Currently, seems that there is no built-in tool on Jetson Thor that reports the memory usage of individual MIG instances. tegrastats only reports aggregate system/GPU usage, and nvidia-smi does not provide a per-MIG memory breakdown on Jetson Thor.
Regarding the SM count, the 12 + 6 split reported by nvidia-smi is a known issue. NVIDIA has acknowledged that the output is incorrect:
“There is a known issue 6162096 — Output of nvidia-smi is incorrect when using MIG. This gives you incorrect information of the SM split being 12 and 6.”
The discussion is available here.
In summary, the remaining 2 SMs are not lost; the discrepancy is due to the current nvidia-smi reporting issue rather than the actual hardware partitioning.
Regards,
Daniel R.
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
If you run with trtexec, it by default contains the memory information:
[06/29/2026-07:35:04] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +9, now: CPU 0, GPU 106 (MiB)
[06/29/2026-07:35:04] [I] Setting persistentCacheLimit to 0 bytes.
[06/29/2026-07:35:04] [I] Created execution context with device memory size: 8.42383 MiB
2.
Please use deviceQuery to check the resource details.
The output of nvidia-smi is incorrect for MIG currently.
$ sudo nvidia-smi -L
GPU 0: NVIDIA Thor (UUID: GPU-a7c66ad2-6dbb-0ab8-c1a2-37ba6dba3600)
  MIG 2g.0gb      Device  0: (UUID: MIG-c465d416-67ab-59e7-b780-1a8f1a762326)
  MIG 1g.0gb      Device  1: (UUID: MIG-b59006b0-f2c1-5668-b295-053748350196)
$ CUDA_VISIBLE_DEVICES=MIG-c465d416-67ab-59e7-b780-1a8f1a762326 ./deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Thor MIG 2g.0gb"
  CUDA Driver Version / Runtime Version          13.2 / 13.2
  CUDA Capability Major/Minor version number:    11.0
  Total amount of global memory:                 125809 MBytes (131920637952 bytes)
  (012) Multiprocessors, (128) CUDA Cores/MP:    1536 CUDA Cores
$ CUDA_VISIBLE_DEVICES=MIG-b59006b0-f2c1-5668-b295-053748350196 ./deviceQuery
Device 0: "NVIDIA Thor MIG 1g.0gb"
  (008) Multiprocessors, (128) CUDA Cores/MP:    1024 CUDA Cores
