Can you please provide sample C/C++ code for CSI/MIPI based Camera using Deep stream
I am trying to run customizable DeepStream (Yolo.v8) on Nvidia AGX Jetson ORIN for basic Pedestrian detection feature with GMSL Camera
(CSI/MIPI based camera’s)
basic deep stream sdk setup is up & running on my Orin (Nvidia AGX Jetson ORIN) & able to run some python based test examples for pedestrian detection,
but I want some C/C++ based sample code for live data from MIPI based camera, so can you please provide sample C/C++ code for the same.
please send any relevant links for the same…
Thanks in advance.
regards,
L V Giribabu.
You may refer to the usage of nvarguscamerasrc in gstreamer command line, there are some example DeepStream SDK FAQ - #15 by Fiona.Chen.
• DeepStream Version
• TensorRT Version
Initially I am trying to run on CPU (without GPU)only, once this setup up & running then will go with GPU
• Hardware Platform (Jetson / GPU) : Jetson AGX Orin
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only) : JetPack 5.1.2
• TensorRT Version : TensorRT 8.5.2
Please let me know still if u need any info, as I mentioned above I want some sample C/C++ code for basic Pedestrian detection feature with GMSL Camera (CSI/MIPI based camera’s) on Deep stream sdk
For CPU only case, please make sure whether the camera supports V4L2.
This is different case. Please check how to set up camera with Jetson Camera Software Development Solution — Jetson Linux Developer Guide documentation (nvidia.com)
For nvargcamerasrc please refer to Accelerated GStreamer — Jetson Linux Developer Guide documentation (nvidia.com)
For v4l2src, plesae refer to DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Thank you for sharing those info,
I will go through it once & let u know if any support is required.
