- Hardware Platform (Jetson / GPU)
- DeepStream Version 5.1
- JetPack Version (valid for Jetson only) 4.51
Issue: How to run deepstream-test with CSI camera in C++. Thanks
Do you mean you want to use CSI camera with deepstream-app?
If so, you can set “type=5” in [source] group in the deepstream-app config file.
No, with deepstream-test 1. I found an example deepstream_python_apps/apps/deepstream-test1-usbcam at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub. in python with US camera.
there is any example with CSI camera (C++), thanks
deepstream-app is open source. You can find the code in /opt/nvidia/deepstream/deepstream/sources/apps
