CAN0 CAN1 回环测试
Jetson AGX Orin Devkit
JetPack 7.2.1 with Jetson Linux 39.2.1
按图示连接CAN0 CAN1
以下是串口执行过程:
root@tegra-ubuntu:/home/chip# busybox devmem 0x0c303018 w 0xc458
root@tegra-ubuntu:/home/chip# busybox devmem 0x0c303010 w 0xc400
root@tegra-ubuntu:/home/chip# busybox devmem 0x0c303008 w 0xc458
root@tegra-ubuntu:/home/chip# busybox devmem 0x0c303000 w 0xc400
root@tegra-ubuntu:/home/chip# modprobe can
root@tegra-ubuntu:/home/chip# modprobe can_raw
root@tegra-ubuntu:/home/chip# modprobe mttcan
root@tegra-ubuntu:/home/chip# ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
root@tegra-ubuntu:/home/chip# ip link set can1 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
root@tegra-ubuntu:/home/chip# candump -x any &
[1] 3336
root@tegra-ubuntu:/home/chip# cansend can0 123#abcdabcd
[ 635.225510] mttcan c310000.mttcan can0: entered error warning state
[ 635.232025] mttcan c310000.mttcan can0: entered error passive state
[ 635.238505] mttcan c310000.mttcan can0: Format Error Detected
[ 635.244431] mttcan_poll_ir: 247 callbacks suppressed
[ 635.249558] mttcan c310000.mttcan can0: IR 0x9810000 PSR 0x77a
[ 635.255607] mttcan c320000.mttanoot@tegra-ubed errhomwarnin# tate
[ 635.262104] mttcan c320000.mttcan can1: entered error passive state
[ 635.268583] mttcan c320000.mttcan can1: Bit0 Error Detected
[ 635.274337] mttcan c320000.mttcan can1: IR 0x9810000 PSR 0x775
[ 635.280408] mttcan c310000.mttcan can0: entered bus off state
[ 635.286345] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 635.292102] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x7e5
root@tegra-ubuntu:/home/chip# ip link set can0 down
root@tegra-ubuntu:/home/chip# ip link set can0 type can bitrate 500000 loopback on
[ 675.926212] mttcan c310000.mttcan can0: Bit0 Error Detected
root@tegra-ubuntu:/home/chip# [ 675.931982] mttcan c310000.mttcan can0: IR 0xa000000 PSR 0x70d
[ 683.035047] mttcan c320000.mttcan can1: Bit0 Error Detected
root@tegra-ubuntu:/home/chip# [ 683.040831] mttcan c320000.mttcan can1: IR 0x8010000 PSR 0x775
can0 RX - - 123 [4] AB CD AB CD
can0 TX - - 123 [4] AB CD AB CD
内部控制器环回是可以的,但是CAN0-CAN1h回环收不到数据。
Internal loopback on only tests the mttcan controller. It does not use J30 pins. That test passing is expected.
CAN0_DIN↔CAN1_DOUT and CAN0_DOUT↔CAN1_DIN cannot work. On AGX Orin DevKit J30 those signals are 3.3 V CAN_TX / CAN_RX, not CANH/CANL. CAN is not UART: the transmitter must monitor its own bits on a wired-AND bus. With a TX/RX crossover, the sender does not see its own dominant bits, so you get Bit0 Error, then error-passive / bus-off. That matches your log (Format Error / Bit0 Error / IR 0x9810000).
For CAN0–CAN1 on Orin you need two transceivers (e.g. WaveShare SN65HVD230):
  • CAN0_DOUT (J30 pin 31) → transceiver0 TX
  • CAN0_DIN (J30 pin 29) → transceiver0 RX
  • CAN1_DOUT (J30 pin 33) → transceiver1 TX
  • CAN1_DIN (J30 pin 37) → transceiver1 RX
  • 3.3 V and GND to both transceivers
  • transceiver0 CANH ↔ transceiver1 CANH
  • transceiver0 CANL ↔ transceiver1 CANL
  • 120 Ω between CANH and CANL at each transceiver
Then (no loopback on; start without FD):
ip link set can1 down
candump -x any &
cansend can1 123#12345678
Pinmux values 0xc458 / 0xc400 are correct for AGX Orin; confirm they read back after devmem. The Thor J47 CAN0_H/CAN1_H short in the same document is for Thor only, not Orin DIN/DOUT.
Please confirm whether transceivers are in the path, and share a photo of CANH/CANL plus termination if it still fails.
Correct external CAN0–CAN1 test (R39.2 CAN guide):
谢谢ShaneCCC。
只剩最后一个问题:如何让这四条配置持久生效?
You can config by jetson-io.
