Setting up CAN
Hi, I’m using two Nvidia Jetson AGX Orin devices, and I’m trying to communicate between them using CAN. I’m attempting to utilize the GPIO can0 on both of them, but encountering some issues.
Below is the script I use to initialize them:
busybox devmem 0x0c303018 w 0x458
busybox devmem 0x0c303010 w 0x400
busybox devmem 0x0c303008 w 0x458
busybox devmem 0x0c303000 w 0x400
sudo modprobe can
sudo modprobe can_raw
sudo modprobe mttcan
sudo ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
However, there is no electronic signal on pin 29 and 31. The GPIO pins are connected to the CAN transceiver. I’m monitoring the signal using Saleae, and I’m concerned that there is absolutely nothing.
Even when using the loopback mode, there is no signal, and even the Loopback test from (Controller Area Network (CAN) — Jetson Linux<br/>Developer Guide 34.1 documentation) doesn’t work (there is nothing in candump). I can send 10 messages, and then I get an error that the buffer is full.
Any help will be appreciated.
Hi szymon.bogucki,
The loopback test here is internal loopback test so that there would not any packet could be captured externally.
How do you send and receive the CAN packet?
Please also share the block diagram of your connection for further check.
