I tried to communicate between can0 and can1 but it is not happening. I have connected the CAN0 and CAN1 transceivers (waveshare) as recommended
I have used following command for setting the ip link as well
$ ip link set can0 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
$ ip link set can1 up type can bitrate 500000 dbitrate 1000000 berr-reporting on fd on
I have also enabled the pins under jetson-io
Hi srivathsan.p,
You could refer to the following thread to verify this use case.
Jetson AGX Xavier Developer Kit CAN commmunication error - #8 by KevinFFF
devkit
Jetpack - 5.1.2
I did verify with this file before posting
also now suddenly i’m not getting any output at all
it is working there was a connectivity issue
system
Closed
February 20, 2024, 9:16am
6
